Print
知
AC+AP跨三层注册典型组网配置案例(集中转发)
2024-09-10 发表
组网及说明
组网说明:
本案例采用H3C HCL模拟器的AC+AP模拟跨三层注册并实现集中转发,在本案例中,DHCP服务器放置在AC1上,AC1与MSW通过配置静态路由,AP通过跨三层网络在AC上注册上线。
1、DHCP服务器放置在MSW。
2、开局前先收集AP的序列号,在AP表面可以看到,或者命令行dis device manunifo命令查看。
配置思路:
1、按照网络拓扑图配置VLAN和IP地址。
2、配置MSW与AC1的三层互联和默认路由协议。
3、在AC1配置AP的注册上线和服务模板、射频接口。
4、AC1开启WEB功能。
配置步骤
(1)SW1
<H3C>sys
[H3C]sysname SW1
[SW1]vlan 10
[SW1-vlan10]quit
[SW1]vlan 20
[SW1-vlan20]quit
[SW1]int gi 1/0/2
[SW1-GigabitEthernet1/0/2]po li acc
[SW1-GigabitEthernet1/0/2]po acc vlan 10
[SW1-GigabitEthernet1/0/2]quit
[SW1]int gi 1/0/1
[SW1-GigabitEthernet1/0/1]po li tr
[SW1-GigabitEthernet1/0/1]undo po tr pe vlan 1
[SW1-GigabitEthernet1/0/1]po tr pe vlan 10 20
[SW1-GigabitEthernet1/0/1]quit
(2)MSW
<H3C>sys
[H3C]sysname MSW
[MSW]vlan 10
[MSW-vlan10]quit
[MSW]vlan 20
[MSW-vlan20]quit
[MSW]int gi 1/0/1
[MSW-GigabitEthernet1/0/1]po li tr
[MSW-GigabitEthernet1/0/1]undo po tr pe vlan 1
[MSW-GigabitEthernet1/0/1]po tr pe vlan 10 20
[MSW-GigabitEthernet1/0/1]quit
[MSW]dhcp enable
[MSW]int vlan 10
[MSW-Vlan-interface10]ip address 192.168.10.1 24
[MSW-Vlan-interface10]quit
[MSW]int vlan 20
[MSW-Vlan-interface20]ip address 192.168.20.1 24
[MSW-Vlan-interface20]quit
[MSW]dhcp server ip-pool vlan10
[MSW -dhcp-pool-vlan10]network 192.168.10.0 mask 255.255.255.0
[MSW -dhcp-pool-vlan10]gateway-list 192.168.10.1
[MSW -dhcp-pool-vlan10]option 138 ip-address 10.0.0.2
[MSW -dhcp-pool-vlan10]quit
[MSW]dhcp server ip-pool vlan20
[MSW -dhcp-pool-vlan20]network 192.168.20.0 mask 255.255.255.0
[MSW -dhcp-pool-vlan20]gateway-list 192.168.20.1
[MSW -dhcp-pool-vlan20]dns-list 114.114.114.114
[MSW -dhcp-pool-vlan20]quit
[MSW]vlan 100
[MSW-vlan100]quit
[MSW]int vlan 100
[MSW-Vlan-interface100]ip address 10.0.0.1 30
[MSW-Vlan-interface100]quit
[MSW]int gi 1/0/2
[MSW-GigabitEthernet1/0/2]po li tr
[MSW-GigabitEthernet1/0/2]undo po tr pe vlan 1
[MSW-GigabitEthernet1/0/2]po tr pe vlan 10 20 100
[MSW-GigabitEthernet1/0/2]quit
[MSW]ip route-static 0.0.0.0 0.0.0.0 10.0.0.2
AC1:
<H3C>sys
[H3C]sysname AC1
[AC1]vlan 10
[AC1-vlan10]quit
[AC1]vlan 20
[AC1-vlan20]quit
[AC1]dhcp enable
[AC1]vlan 100
[AC1-vlan100]quit
[AC1]int vlan 100
[AC1-Vlan-interface100]ip address 10.0.0.2 30
[AC1-Vlan-interface100]quit
[AC1]int gi 1/0/2
[AC1-GigabitEthernet1/0/2]po li tr
[AC1-GigabitEthernet1/0/2]undo po tr pe vlan 1
[AC1-GigabitEthernet1/0/2]po tr pe vlan 10 20 100
[AC1-GigabitEthernet1/0/2]quit
[AC1]wlan service-template weijianing
[AC1-wlan-st-weijianing]ssid weijianing
[AC1-wlan-st-weijianing]vlan 20
[AC1-wlan-st-weijianing]client forwarding-location ac
[AC1-wlan-st-weijianing]service-template enable
[AC1-wlan-st-weijianing]quit
[AC1]wlan auto-ap enable
[AC1]wlan auto-persistent enable
[AC1]wlan global-configuration
[AC1-wlan-global-configuration]firmware-upgrade disable
[AC1-wlan-global-configuration]quit
[AC1]wlan ap AP1 model WA6320-HCL
[AC1-wlan-ap-AP1]serial-id H3C_B0-DB-D3-C1-03-00
[AC1-wlan-ap-AP1]vlan 10
[AC1-wlan-ap-AP1-vlan10]quit
[AC1-wlan-ap-AP1]vlan 20
[AC1-wlan-ap-AP1-vlan20]quit
[AC1-wlan-ap-AP1]radio 1
[AC1-wlan-ap-AP1-radio-1]radio enable
[AC1-wlan-ap-AP1-radio-1]service-template weijianing vlan 20
[AC1-wlan-ap-AP1-radio-1]quit
[AC1-wlan-ap-AP1]radio 2
[AC1-wlan-ap-AP1-radio-2]radio enable
[AC1-wlan-ap-AP1-radio-2]service-template weijianing vlan 20
[AC1-wlan-ap-AP1-radio-2]quit
[AC1-wlan-ap-AP1]quit
[AC1]ip route-static 0.0.0.0 0.0.0.0 10.0.0.1
在AC查看AP上线情况,发现已上线。
把手机加入到模拟器,并启动。
选中手机,右键“配置”
打开WIFI
选中相应的信号,并打开连接的开关
手机能获取到IP地址。
同时手机能跨网段PING通。
在AC能看到手机注册上线后的信息。
至此,AC+AP跨三层注册典型组网配置案例已完成!
