Print
知
EVPN L3VPNv4 over OSPFv3 SRv6 BE典型配置案例
2024-09-21 发表
组网及说明
配置步骤
1、配置IGP互通(OSPFv3),PE之间环回口IPv6路由可达;
2、配置PE和CE之间建立EBGP邻居,CE引入路由到PE的VPN实例路由表;
3、PE之间建立MP-IBGP邻居;
4、配置SRv6 BE隧道,并发布EVPN路由
配置步骤
关键配置
 sysname pe_01
ip vpn-instance v1
 route-distinguisher 100:1
 vpn-target 101:1 import-extcommunity
 vpn-target 101:1 export-extcommunity
ospfv3 1
 router-id 1.1.1.1
 segment-routing ipv6 locator pe_01
 area 0.0.0.0
interface LoopBack0
 ip address 1.1.1.1 255.255.255.0
 ospfv3 1 area 0.0.0.0
 ipv6 address 1::1/128
interface GigabitEthernet0/0/0
 port link-mode route
 combo enable copper
 ip binding vpn-instance v1
 ip address 14.1.1.1 255.255.255.0
interface GigabitEthernet0/0/1
 combo enable copper
 ipv6 address 12::1/64
bgp 65000
 peer 3::3 as-number 65000
 peer 3::3 connect-interface LoopBack0
 address-family l2vpn evpn
  peer 3::3 enable
  peer 3::3 advertise encap-type srv6
 ip vpn-instance v1
  peer 14.1.1.4 as-number 65004
  address-family ipv4 unicast
   segment-routing ipv6 best-effort evpn
   segment-routing ipv6 locator pe_01 evpn
   peer 14.1.1.4 enable
 encapsulation source-address 1::1
 locator pe_01 ipv6-prefix C100:: 96 static 8
 sysname pe_03
ip vpn-instance v1
ospfv3 1
 router-id 3.3.3.3
 segment-routing ipv6 locator pe_03
 area 0.0.0.0
interface LoopBack0
 ip address 3.3.3.3 255.255.255.255
 ipv6 address 3::3/128
 combo enable copper
 ip address 35.1.1.3 255.255.255.0
 combo enable copper
 ipv6 address 23::3/64
bgp 65000
 peer 1::1 as-number 65000
 peer 1::1 connect-interface LoopBack0
  peer 1::1 enable
  peer 1::1 advertise encap-type srv6
 ip vpn-instance v1
  peer 35.1.1.5 as-number 65005
   segment-routing ipv6 locator pe_03 evpn
   peer 35.1.1.5 enable
 encapsulation source-address 3::3
 locator pe_03 ipv6-prefix C300:: 96 static 8
Locator和Local-SID信息
<pe_01>disp segment-routing ipv6 locator
                      Locator configuration table
Locator name        : pe_01                                 Flag(A)       : 0
IPv6 prefix         : C100::                                Prefix length : 96
Static length       : 8                                     Args length   : 0
Common prefix length: 0
Algorithm           : 0
Auto SID start      : C100::100
Auto SID end        : C100::FFFF:FFFF
Static SID start    : C100::1
Static SID end      : C100::FF    ----静态段长度为8
Compressed Auto SID count      : 0
Compressed Static SID count    : 0
Non-compressed Auto SID count  : 3
Non-compressed Static SID count: 0
<pe_03>disp segment-routing ipv6 locator
Locator name        : pe_03                                 Flag(A)       : 0
IPv6 prefix         : C300::                                Prefix length : 96
Algorithm           : 0
Auto SID start      : C300::100
Auto SID end        : C300::FFFF:FFFF
Static SID start    : C300::1
Static SID end      : C300::FF
<pe_01>disp segment-routing ipv6 local-sid
                    Local SID forwarding table
Total SIDs: 3
SID           : C100::101/96
Function type : End                             Flavor         : PSP
Locator name  : pe_01                           Allocation type: Dynamic
Owner         : OSPFV3-1                        State          : Active
Create Time   : Sep 15 15:34:51.463 2024
SID           : C100::102/96
Function type : End.X                           Flavor         : PSP
Interface     : GE0/0/1                         Interface index: 0x2
Next hop      : FE80::54CC:AEFF:FE36:205        Allocation type: Dynamic
Create Time   : Sep 15 15:34:51.469 2024
SID           : C100::100/96
Function type : End.DT4                         Flavor         : PSP
VPN instance  : v1                              Allocation type: Dynamic
Network type  : EVPN L3VPN
Owner         : BGP                             State          : Active
Create Time   : Sep 15 15:25:06.143 2024
<pe_03>disp segment-routing ipv6 local-sid
Total SIDs: 3
SID           : C300::100/96
Locator name  : pe_03                           Allocation type: Dynamic
Create Time   : Sep 15 15:38:04.172 2024
SID           : C300::101/96
Next hop      : FE80::54CC:AEFF:FE36:206        Allocation type: Dynamic
Create Time   : Sep 15 15:38:04.180 2024
SID           : C300::102/96
Create Time   : Sep 15 15:40:10.715 2024
IPv4路由传递过程(控制平面)
<ce_04>disp bgp routing-table ipv4 4.4.4.4
 BGP local router ID: 4.4.4.4
 Local AS number: 65004
 Paths:   1 available, 1 best
 BGP routing table information of 4.4.4.4/32:
 Imported route.
 Original nexthop: 127.0.0.1
 OutLabel        : NULL
 AS-path         : (null)
 Origin          : igp
 Attribute value : MED 0, pref-val 32768
 State           : valid, local, best
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 VPN-Peer UserID : N/A
 DSCP            : N/A
 EXP             : N/A
 Tunnel policy   : NULL
 Rely tunnel IDs : N/A
<pe_01>disp bgp routing-table vpnv4 4.4.4.4
 BGP local router ID: 1.1.1.1
 Local AS number: 65000
 Route distinguisher: 100:1(v1)
 Total number of routes: 1
 Rely nexthop    : 14.1.1.4
 Original nexthop: 14.1.1.4
 Out interface   : GigabitEthernet0/0/0
 Route age       : 01h36m47s
 OutLabel        : NULL
 Ext-Community   : <RT: 101:1>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 65004
 Origin          : igp
 Source type     : local
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
<pe_01>disp bgp l2vpn evpn  [5][0][32][4.4.4.4]/80
 BGP routing table information of [5][0][32][4.4.4.4]/80:
 Route age       : 01h24m50s
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 PrefixSID       : End.DT4 SID <C100::100>
 AS-path         : 65004
 Origin          : igp
 State           : valid, external, best, localredist
 Source type     : local-import
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : IP prefix advertisement route
 ESI             : 0000.0000.0000.0000.0000
 Ethernet tag ID : 0
 IP prefix       : 4.4.4.4/32
 Gateway address : 0.0.0.0
 MPLS label      : 4294967295
<pe_03>disp bgp l2vpn evpn  [5][0][32][4.4.4.4]/80
 BGP local router ID: 3.3.3.3
 Rely nexthop    : FE80::54CC:AEFF:FE36:206
 Original nexthop: 1::1
 Out interface   : GigabitEthernet0/0/1
 Route age       : 01h24m13s
 OutLabel        : 3
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 65004
 Origin          : igp
 State           : valid, internal, best
 Source type     : local
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 Ethernet tag ID : 0
 MPLS label      : 3
 Re-orignination : Disable
<pe_03>disp bgp routing-table vpnv4 4.4.4.4
 Route age       : 01h24m54s
 OutLabel        : 3
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 65004
 Origin          : igp
 State           : valid, internal, best, remoteredist
 Source type     : evpn remote-import
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
<ce_05> disp bgp rou ipv4 4.4.4.4
 BGP local router ID: 5.5.5.5
 Local AS number: 65005
 Rely nexthop    : 35.1.1.3
 Original nexthop: 35.1.1.3
 OutLabel        : NULL
 AS-path         : 65000 65004
 Origin          : igp
 Attribute value : pref-val 0
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 DSCP            : N/A
 EXP             : N/A
数据转发
<ce_05>disp ip rou 4.4.4.4
Summary count : 1
4.4.4.4/32         BGP     255 0           35.1.1.3        GE0/0
<pe_03>disp fib v v1 4.4.4.4
FIB entry count: 1
Flag:
  R:Relay     F:FRR
4.4.4.4/32         FE80::54CC:AEFF UGHR     GE0/0/1                  Null
                   :FE36:206
<pe_03>disp ip rou v v1 4.4.4.4
Summary count : 1
4.4.4.4/32         BGP     255 0           C100::          GE0/0/1
<pe_03>disp ipv6 rou c100::
Summary count : 1
Destination: C100::/96                                   Protocol  : O_INTRA
NextHop    : FE80::54CC:AEFF:FE36:206                    Preference: 10
Interface  : GE0/0/1                                     Cost      : 2
<p_02>disp ipv6 rou c100::
Summary count : 1
NextHop    : FE80::54CC:A9FF:FE73:106                    Preference: 10
Interface  : GE0/0/0                                     Cost      : 1
<pe_01>disp ipv6 routing-table c100::
Summary count : 2
NextHop    : ::                                          Preference: 10
Interface  : NULL0                                       Cost      : 0
Destination: C100::/128                                  Protocol  : SRv6
NextHop    : ::1                                         Preference: 4
Interface  : InLoop0                                     Cost      : 0
<pe_01>disp fib v v1 4.4.4.4
FIB entry count: 1
Flag:
  R:Relay     F:FRR
4.4.4.4/32         14.1.1.4        UGHR     GE0/0/0                  Null
<pe_01>disp ip rou v v1 4.4.4.4
Summary count : 1
4.4.4.4/32         BGP     255 0           14.1.1.4        GE0/0/0
配置关键点
不涉及
