Print
知
【3PAR】3PAR告警HPE 3PAR OS version is not the same on all nodes
2024-09-27 发表
问题描述
过程分析
cli% showsys
        ----------------(MiB)-----------------
     ID -------Name-------- ----Model---- --Serial-- Nodes Master ClusterLED  TotalCap  AllocCap  FreeCap FailedCap
0x1zzzz yyyy-VM-xxxx-3PAR01 HPE_3PAR 8450 6CU7xxxxxx     4      1 Off        205004800 172910592 32094208         0
cli% showversion
Release version 3.3.1 (MU5)
Patches:  P126,P132,P135,P140,P146,P150,P151,P155,P156,P164,P170,P172,P173,P177,P180
问题分析:
cli% shownode
        Control    Data        Cache
Node ----Name---- -State- Master InCluster -Service_LED ---LED--- Mem(MB) Mem(MB) Available(%)
   0 6CU7xxxxxx-0 OK      No     Yes       Off          GreenBlnk   65536   32768          100
   1 6CU7xxxxxx-1 OK      Yes    Yes       Off          GreenBlnk   65536   32768          100
   2 6CU7xxxxxx-2 OK      No     Yes       Off          GreenBlnk   65536   32768          100
   3 6CU7xxxxxx-3 OK      No     Yes       Off          GreenBlnk   65536   32768          100
工程师更换完故障node2后回灌系统成功,存储运行正常,但是checkhealth确提示“HPE 3PAR OS version is not the same on all nodes”
cli% checkhealth -detail -svc node
Checking node
Component --------------Summary Description--------------- Qty
Node controlrecoveryauth issues 3
Node HPE 3PAR OS version is not the same on all nodes 1
Node Package list is not the same on all nodes 1
3 total 5
Component -Identifier- --------------------Detailed Description---------------------
Node -- Ciphertext password for console account not same on all nodes
Node -- Ciphertext password for root account not same on all nodes
Node -- HPE 3PAR OS version is not the same on all nodes    <<<<<<<<<<
Node -- Package list is not the same on all nodes
Node node2 Nodes with strong password disable file
解决方法
根据信息判断node2系统回灌后个别文件异常导致的
重新对node2执行noderescue,再checkhealth一切正常
