Print
知
F5000防火墙RBM+VRRP主备切换异常经验案例
2024-09-27 发表
组网及说明
组网:
问题描述
RBM切换测试中主设备DOWN掉上行接口后,主设备vrrp状态切换为Initialize状态,备设备仍然保持Backup状态不进行切换。
过程分析
1、组网:标准组网,主备设备上行口均为1/0/1
2、主设备DOWN掉1/0/1接口后vrrp变化:
  ===============display vrrp verbose===============
 Running mode      : Standard
RBM control channel is established
   VRRP active group status : Master
   VRRP standby group status: Master
Total number of virtual routers : 9
     VRID (group)   : 14 (Active)         Adver Timer  : 100
     Admin Status   : Up                  State        : Initialize
     Config Pri     : 100                 Running Pri  : 100
     Preempt Mode   : Yes                 Delay Time   : 0
     Auth Type      : Not supported
     Version        : 3
     Virtual IP     : 111.2.177.40/32
     Master IP      : 0.0.0.0
此时备设备vrrp状态:
   VRRP active group status : Backup
   VRRP standby group status: Backup
     VRID (group)   : 14 (Standby)        Adver Timer  : 100
     Admin Status   : Up                  State        : Backup
     Become Master  : --
     Version        : 3
     Master IP      : 111.2.177.41
3、故障时主设备隧道情况查看如下,且测试两端HA通道互通:
RBM_P<F5030-6GW>dis rem st
Remote backup group information:
  Backup mode: Active/standby
  Device management role: Primary
  Device running status: Active
  Data channel interface: GigabitEthernet1/7/4
  Local IP: 192.168.x.1
  Remote IP: 192.168.x.2    Destination port: 60064
  Control channel status: Connected
  Keepalive interval: 1s
  Keepalive count: 10
  Configuration consistency check interval: 12 hour
  Configuration consistency check result: Consistent(2024-08-11 16:21:41)
  Configuration backup status: Auto sync enabled
  Session backup status: Hot backup enabled
  Delay-time: 1 min
  Uptime since last switchover: 0 days, 0 hours, 40 minutes
  Switchover records:
    Time                  Status change        Cause
    2024-08-11 15:48:44   Standby to Active    Switchover request
    2024-08-11 15:13:18   Active to Standby    Switchover request
    2024-08-11 15:07:29   Active to Active     Keepalive link established
    2024-08-11 14:49:33   Standby to Active    Interface status changed
    2024-08-11 14:49:33   Active to Standby    The local device quits the remote backup group
    2024-08-11 14:47:05   Initial to Active    The local device quits the remote backup group
    2024-08-11 14:43:54   Active to Standby    The local device quits the remote backup group
    2024-08-11 13:24:11   Active to Active     Keepalive link established
    2024-08-11 13:23:50   Standby to Active    Keepalive link established
    2024-08-11 13:06:56   Active to Standby    Interface status changed
<F5030-6GW>ping 192.168.x.2
Ping 192.168.x.2 (192.168.x.2): 56 data bytes, press CTRL+C to break
56 bytes from 192.168.X.2: icmp_seq=0 ttl=255 time=1.085 ms
56 bytes from 192.168.X.2: icmp_seq=1 ttl=255 time=0.351 ms
56 bytes from 192.168.X.2: icmp_seq=2 ttl=255 time=1.151 ms
56 bytes from 192.168.X.2: icmp_seq=3 ttl=255 time=1.138 ms
56 bytes from 192.168.X.2: icmp_seq=4 ttl=255 time=0.368 ms
--- Ping statistics for 192.168.X.2 ---
故障时备设备HA状态查看,且测试两端HA通道互通:
RBM_S<H3C>dis rem st
  Device management role: Secondary
  Device running status: Standby
  Local IP: 192.168.X.2
  Remote IP: 192.168.X.1    Destination port: 60064
  Keepalive count: 10
  Configuration consistency check result: Not Performed
  Uptime since last switchover: 0 days, 0 hours, 39 minutes
  Switchover records:
    2024-08-11 15:46:07   Active to Standby    Switchover request
    2024-08-11 15:10:41   Standby to Active    Switchover request
    2024-08-11 15:04:53   Standby to Standby   Keepalive link established
    2024-08-11 14:46:56   Active to Standby    Interface status changed
    2024-08-11 14:46:56   Active to Active     The peer device quits the remote backup group
    2024-08-11 14:41:35   Active to Active     Keepalive link disconnected
    2024-08-11 14:41:18   Standby to Active    The peer device quits the remote backup group
    2024-08-11 13:21:35   Standby to Standby   Keepalive link established
    2024-08-11 13:21:14   Active to Standby    Keepalive link established
    2024-08-11 13:04:20   Standby to Active    Interface status changed
RBM_S<H3C>ping 192.168.X.1
Ping 192.168.X.1 (192.168.254.1): 56 data bytes, press CTRL+C to break
56 bytes from 192.168.X.1: icmp_seq=0 ttl=255 time=0.454 ms
56 bytes from 192.168.X.1: icmp_seq=1 ttl=255 time=1.154 ms
56 bytes from 192.168.X.1: icmp_seq=2 ttl=255 time=1.101 ms
56 bytes from 192.168.X.1: icmp_seq=3 ttl=255 time=0.402 ms
56 bytes from 192.168.X.1: icmp_seq=4 ttl=255 time=0.267 ms
--- Ping statistics for 192.168.X.1 ---
4、此时注意到现场组网,现场配置了多组RBM+VRRP,检查备机其他组VRRP状态是异常的,其他组备机VRRP状态异常相当于备机的状态是异常的。
解决方法
现场配置了多组VRRP+RBM,一组VRRP状态异常的话会影响整个设备的RBM状态,检查时需要检查所有VRRP组状态。现场这组VRRP状态异常的原因是因为未接网线,接好网线后切换测试恢复正常。
