Print
知
某局点 SecPath F5030-6GW-G(V7) SSLVPN不通
2024-11-29 发表
组网及说明
SecPath F5030-6GW-G(V7),Version 7.1.064, Release 8160P47
问题描述
现场两台F5030-6GW-G防火墙RBM主备+VRRP组网,VRRP虚地址与接口地址不在一个网段,做了SSLVPN不通,iNode登录SSLVPN提示,查询网关参数失败
过程分析
(以下敏感信息已做脱敏处理)
公网地址:100.252.15.38    SSLVPN端口号:50000
查看现场SSLVPN配置,没有发现问题,查看会话,每次iNode登录,dis session table ipv4 destination-ip 100.252.15.38 destination-port 50000 verbose查看是有会话的,防火墙上是有会话产生的,进一步debug查看
先写一个到防火墙公网地址的ACL
acl advanced 3003
 rule 0 permit tcp destination 100.252.15.38 0 destination-port eq 50000
 rule 6 permit tcp source 100.252.15.38 0 source-port eq 50000
然后开启debug
debugging ip packet acl 3XXX
debugging ip info acl 3XXX
debugging aspf packet acl 3XXX
debugging security-policy packet ip acl 3XXX
 IPFW/7/IPFW_PACKET: -COntext=1;
Sending, interface = GigabitEthernet1/0/1
version = 4, headlen = 20, tos = 0
pktlen = 60, pktid = 1182, offset = 0, ttl = 255, protocol = 6
checksum = 39113, s = 100.252.15.38, d = 33.170.47.136
channelID = 0, vpn-InstanceIn = 0, vpn-InstanceOut = 0.
VsysID = 1
prompt: Sending IP packet from local at interface GigabitEthernet1/0/1.
Payload: TCP
  source port = 50000, destination port = 32268
  sequence num = 0xa3f2617c, acknowledgement num = 0x450ac2c1, flags = 0x12
  window size = 65535, checksum = 0x2e53, header length = 40.
Delivering, interface = GigabitEthernet1/0/4
version = 4, headlen = 20, tos = 116
pktlen = 60, pktid = 28230, offset = 0, ttl = 56, protocol = 6
checksum = 46509, s = 33.170.47.136, d = 100.252.15.38
VsysID = 1
prompt: Forwarding IP packet to upper layer from FastForward.
Payload: TCP
  source port = 32268, destination port = 50000
  sequence num = 0x450ac2c0, acknowledgement num = 0x00000000, flags = 0x2
  window size = 64240, checksum = 0x121f, header length = 40.
解决方法
从上述debug可以看到,进防火墙的接口和出防火墙的接口不一致,在进来的端口配置ip last-hop hold保持上一跳使流量出去走同一个接口之后解决
