Print
知
nat66配置全局nat实现内网前缀转换成单个公网ipv6地址
2024-11-30 发表
组网及说明
防火墙作为出口设备,配置96前缀的ipv6地址,内网的1000::1/64和1001::1/64前缀的网段转换成公网的2000::3地址访问外网,内网的1003::1/64和1004::1/64前缀的网段转换成公网的2000::4地址访问外网。
配置步骤
防火墙配置:
interface GigabitEthernet1/0/2   //外网口配置
 port link-mode route
 combo enable copper
 ipv6 address 2000::1/96
 proxy-nd enable    //普通的arp代理这个是必须配置的
interface GigabitEthernet1/0/3   //内网口配置
 combo enable copper
 ipv6 address 2001::1/96
安全域配置:
security-zone name Trust
 import interface GigabitEthernet1/0/3
security-zone name Untrust
 import interface GigabitEthernet1/0/2
安全策略配置:
security-policy ipv6
 rule 1 name trust_untrust
  action pass
  source-zone trust
  destination-zone untrust
指向内网网段的路由配置
 ipv6 route-static 1000:: 64 2001::2
 ipv6 route-static 1001:: 64 2001::2
 ipv6 route-static 1003:: 64 2001::3
 ipv6 route-static 1004:: 64 2001::3
创建nat地址对象组
object-group ipv6 address test
 0 network host address 2000::3
object-group ipv6 address test1
 0 network host address 2000::4
全局nat配置:
nat global-policy
 rule name 1 type nat66
  source-zone Trust
  destination-zone Untrust
  source-ip subnet 1000:: 64     //源地址是1000:: 64前缀的转换成test地址组中的地址
  source-ip subnet 1001:: 64     //源地址是1001:: 64前缀的转换成test地址组中的地址
  action snat object-group test
 rule name 2 type nat66
  source-zone Trust
  source-ip subnet 1003:: 64      //源地址是1003:: 64前缀的转换成test1地址组中的地址
  source-ip subnet 1004:: 64      //源地址是1004:: 64前缀的转换成test1地址组中的地址
  action snat object-group test1
配置关键点
测试结果:
<H3C>ping ipv6 -a 1000::1 2000::2
Ping6(56 data bytes) 1000::1 --> 2000::2, press CTRL+C to break
56 bytes from 2000::2, icmp_seq=0 hlim=63 time=1.662 ms
56 bytes from 2000::2, icmp_seq=1 hlim=63 time=1.346 ms
56 bytes from 2000::2, icmp_seq=2 hlim=63 time=1.587 ms
56 bytes from 2000::2, icmp_seq=3 hlim=63 time=1.042 ms
56 bytes from 2000::2, icmp_seq=4 hlim=63 time=1.027 ms
<H3C>ping ipv6 -a 1001::1 2000::2
Ping6(56 data bytes) 1001::1 --> 2000::2, press CTRL+C to break
56 bytes from 2000::2, icmp_seq=0 hlim=63 time=4.393 ms
56 bytes from 2000::2, icmp_seq=1 hlim=63 time=1.954 ms
56 bytes from 2000::2, icmp_seq=2 hlim=63 time=1.121 ms
56 bytes from 2000::2, icmp_seq=3 hlim=63 time=1.125 ms
56 bytes from 2000::2, icmp_seq=4 hlim=63 time=1.175 ms
查看会话:
<H3C>dis nat66 session verbose
Slot 1:
Total sessions found: 0
Slot 1:
Initiator:
  Source      IP/port: 1001::1/11060
  Destination IP/port: 2000::2/32768
  Protocol: IPV6-ICMP(58)
  Inbound interface: GigabitEthernet1/0/3
  Source security zone: Trust
Responder:
  Source      IP/port: 2000::2/6
  Destination IP/port: 2000::3/33024
  Inbound interface: GigabitEthernet1/0/2
  Source security zone: Untrust
State: ICMPV6_REPLY
Application: ICMP
Rule ID: 1
Rule name: trust_untrust
Start time: 2024-11-30 09:55:46  TTL: 25s
Initiator->Responder:            0 packets          0 bytes
Responder->Initiator:            0 packets          0 bytes
Initiator:
  Source      IP/port: 1000::1/11061
Responder:
  Source      IP/port: 2000::2/7
State: ICMPV6_REPLY
Application: ICMP
Rule ID: 1
Start time: 2024-11-30 09:55:49  TTL: 27s
Total sessions found: 2
<H3C>ping ipv6 -a 1003::1 2000::2
Ping6(56 data bytes) 1003::1 --> 2000::2, press CTRL+C to break
56 bytes from 2000::2, icmp_seq=0 hlim=63 time=2.509 ms
56 bytes from 2000::2, icmp_seq=1 hlim=63 time=1.584 ms
56 bytes from 2000::2, icmp_seq=2 hlim=63 time=1.889 ms
56 bytes from 2000::2, icmp_seq=3 hlim=63 time=1.153 ms
56 bytes from 2000::2, icmp_seq=4 hlim=63 time=1.968 ms
<H3C>ping ipv6 -a 1004::1 2000::2
Ping6(56 data bytes) 1004::1 --> 2000::2, press CTRL+C to break
56 bytes from 2000::2, icmp_seq=0 hlim=63 time=2.129 ms
56 bytes from 2000::2, icmp_seq=1 hlim=63 time=1.758 ms
56 bytes from 2000::2, icmp_seq=2 hlim=63 time=2.058 ms
56 bytes from 2000::2, icmp_seq=3 hlim=63 time=1.387 ms
56 bytes from 2000::2, icmp_seq=4 hlim=63 time=1.041 ms
查看会话:
Slot 1:
Initiator:
  Source      IP/port: 1004::1/52749
Responder:
  Destination IP/port: 2000::4/33024
State: ICMPV6_REPLY
Application: ICMP
Rule ID: 1
Start time: 2024-11-30 09:56:44  TTL: 26s
Initiator:
  Source      IP/port: 1003::1/52748
Responder:
  Source      IP/port: 2000::2/5
State: ICMPV6_REPLY
Application: ICMP
Rule ID: 1
Start time: 2024-11-30 09:56:39  TTL: 21s
