Print
【MVS】HP 3500yl 交换机如何恢复出厂设置
2024-12-06 发表
问题描述
解决方法
You can restore the factory default configuration either on the switch itself, or through the switch console.
To execute the factory default reset on the switch, perform these steps:
1.Using pointed objects, simultaneously press both the Reset and Clear buttons on the front of the switch.
2.Continue to press the Clear button while releasing the Reset button.
3.When the Self Test LED begins to blink, release the Clear button. It takes approximately 25 seconds before the Self Test LED will begin to blink.
The switch will then complete its self test and begin operating with its configuration restored to the factory default settings.
To restore the factory default configuration using the console, execute the erase startup-configcommand from the console command prompt.
