Print
知
CR16000-M1A设备部分接口不可用
1小时前 发表
组网及说明
不涉及
告警信息
无
问题描述
现场反馈路由器查看display interface brief发现设备只有部分接口可用,其他接口不显示,但是设备外观上不止显示的这些接口。
过程分析
解决方法
这个设备有两个模式,对应部分接口可用
切换命令如下,切换需要重启。现场根据接口需求灵活修改模式。如果不能满足需求建议现场联系市场。
[DUT]port-working-mode ?
  hg2-card  Specify the hg2-card mode. In this mode, only six GE ports (1 to 6),
            20 XGE ports (7 to 26), two HE ports (27 and 28), four GE copper
            ports (31 to 34) and the card slot are available
  hg4-xp12  Specify the hg4-xp12 mode. In this mode, only four HGE ports (27 to
            30) and 12 XGE ports (15 to 26) are available
[DUT]display port-working-mode
Current port working mode: hg2-card. Specify the hg2-card mode. In this mode, only six GE ports (1 to 6), 20 XGE ports (7 to 26), two HE ports (27 and 28), four GE copper ports (31 to 34) and the card slot are available
Next    port working mode: hg2-card. Specify the hg2-card mode. In this mode, only six GE ports (1 to 6), 20 XGE ports (7 to 26), two HE ports (27 and 28), four GE copper ports (31 to 34) and the card slot are available
