Print
知
某局点过设备NAT转发异常
18小时前 发表
组网及说明
不涉及
问题描述
设备MSR3620在出口位置,做了NAT Server,将内网一台服务器映射到公网,服务器提供了WEB服务,在WEB上可以访问服务器上的虚机,虚机地址和服务器地址一样,但是端口不同
interface Ten-GigabitEthernet0/X
ip address X.X.X.X 255.255.255.252
nat outbound
nat server protocol tcp global current-interface A inside 192.168.1.D 443
nat server protocol tcp global current-interface B inside 192.168.1.D Y
nat server protocol tcp global current-interface C inside 192.168.1.D Z
在公网访问测试,能打开WEB界面,但是访问WEB上的虚机时无法连接。
过程分析
在内网通过WEB界面访问虚机正常,说明服务器是正常的,虚机也是正常的,在设备debug,看到访问过程是正常的:
<H3C>*Nov 18 19:07:26:139 2024 H3C IPFW/7/IPFW_PACKET:
Receiving, interface = Ten-GigabitEthernet0/X
version = 4, headlen = 20, tos = 4
pktlen = 52, pktid = 35599, offset = 0, ttl = 112, protocol = 6
checksum = 34526, s = 221.12.4.143, d = X.X.X.X
channelID = 0, vpn-InstanceIn = 0, vpn-InstanceOut = 0.
VsysID = 1
prompt: Receiving IP packet from interface Ten-GigabitEthernet0/X.
Payload: TCP
  source port = 62060, destination port = B
  sequence num = 0xc0427819, acknowledgement num = 0x00000000, flags = 0x2
  window size = 64240, checksum = 0x8881, header length = 32.
*Nov 18 19:07:26:139 2024 H3C NAT/7/COMMON:
 PACKET: (Ten-GigabitEthernet0/20-in-config) Protocol: TCP
    221.12.4.143:62060 -   X.X.X.X:B(VPN:    0)(vsys:    1) ------>
    221.12.4.143:62060 -   192.168.1.D: Y(VPN:    0)(vsys:    1)
*Nov 18 19:07:26:140 2024 H3C IPFW/7/IPFW_PACKET:
Sending, interface = Vlan-interface1
pktlen = 52, pktid = 35599, offset = 0, ttl = 111, protocol = 6
checksum = 56483, s = 221.12.4.143, d = 192.168.1.D
VsysID = 1
prompt: Sending IP packet received from interface Ten-GigabitEthernet0/X at interface Vlan-interface1.
Payload: TCP
  source port = 62060, destination port = Y
  window size = 64240, checksum = 0x9905, header length = 32.
Receiving, interface = Vlan-interface1
version = 4, headlen = 20, tos = 0
pktlen = 52, pktid = 0, offset = 0, ttl = 64, protocol = 6
checksum = 38583, s = 192.168.1.D, d = 221.12.4.143
VsysID = 1
prompt: Receiving IP packet from interface Vlan-interface1.
Payload: TCP
  source port = Y, destination port = 62060
  sequence num = 0xca824f67, acknowledgement num = 0xc042781a, flags = 0x12
  window size = 29200, checksum = 0x0738, header length = 32.
*Nov 18 19:07:26:140 2024 H3C NAT/7/COMMON:
 PACKET: (Ten-GigabitEthernet0/X-out-session) Protocol: TCP
   192.168.1.D: Y -    221.12.4.143:62060(VPN:    0)(vsys:    1) ------>
   X.X.X.X:B -    221.12.4.143:62060(VPN:    0)(vsys:    1)
Sending, interface = Ten-GigabitEthernet0/X
pktlen = 52, pktid = 0, offset = 0, ttl = 63, protocol = 6
checksum = 17138, s = X.X.X.X, d = 221.12.4.143
VsysID = 1
prompt: Sending IP packet received from interface Vlan-interface1 at interface Ten-GigabitEthernet0/X.
Payload: TCP
  source port = B, destination port = 62060
  window size = 29200, checksum = 0xf81b, header length = 32.
进一步在内网测试,发现通过软件登录时,使用了443端口,而非Y端口,所以怀疑通过WEB访问时,被重定向到了一个内网端口,从公网发起访问时,没有访问到真正的服务,为验证猜测,在接口下新增如下配置,转换时端口不变,新增配置后测试访问正常。
nat server protocol tcp global current-interface Y inside 192.168.1.D Y
nat server protocol tcp global current-interface Z inside 192.168.1.D Z
解决方法
内网服务器WEB上访问虚机经过了一次端口跳转,且跳转的是内网真实端口,所以该端口也需要在公网进行映射。
