Print
知
某局点S7506X-G portal认证频繁上下线
2025-01-25 发表
问题描述
过程分析
1、终端portal认证成功后,立马就掉了,配置暂无问题。
2、查看debug信息可以看到,交互完radius报文后,交换机发送了:
Portal sent 46 bytes of packet: Type=ack_auth(4), ErrCode=0, IP=192.168.x.x
*Dec 16 06:06:16:205 2024 SW-CORE PORTAL/7/PACKET:
[ 11 SESSIONID           ] [  8] [000e-xxxx-xxxx]
[ 10 BASIP               ] [  6] [192.168.x.x]
3、然后服务器回:
Portal received 32 bytes of packet: Type=aff_ack_auth(7), ErrCode=0, IP=192.168.x.x
*Dec 16 06:06:16:400 2024 SW-CORE PORTAL/7/PACKET:
02 07 01 00 31 a1 00 00 c0 a8 32 01 00 00 00 00
38 bc 63 00 64 de 82 ee 58 e6 98 5c 8d 28 a6 18
说明此时认证完成结束了。
但是紧接着,交换机发了logout报文,导致认证用户下线:
*Dec 16 06:06:16:403 2024 SW-CORE PORTAL/7/PACKET:
Portal sent 63 bytes of packet: Type=ntf_logout(8), ErrCode=0, IP=192.168.x.x
[  5 TEXTINFO            ] [ 25] [Failed to set user rule]
4、服务器侧报错:
5、debug发送下线报文的原因是Failed to set user rule,一般是acl资源不足或者是AAA服务器下发而设备不能正常执行的授权规则导致的acl资源我看过是足够的,怀疑是aaa那边下发了设备无法执行的授权规则。但是后续将domain域里的授权改为none了之后故障依旧。
6、debug报错,底层acl规则不支持匹配聚合:
*Dec 16 06:06:16:403 2024 SW-CORE PORTAL/7/RULE:
 DRV_USER_RULE:
   L2 Interface     = Bridge-Aggregation99
    L3 Interface     = Vlan-interface50
    VLAN             = 50
    SrcIP            = 192.168.x.x
    SrcMAC           = 000e-xxxx-xxxx
    AuthorACL        = 4294967295
    Operation        = 1
    SetDrvFlag       = 0
    TrafficLevelNum  = 0
    TrafficLevelMap  = 0x0
    TrafficActiOnMap= 0x0
    UserID           = 268437813
    VrfIndex         = 0
    AclMismatchAction= 0
    MicroSegmentID   = 0
*Dec 16 06:06:16:403 2024 SW-CORE PORTAL/7/EVENT: Start scanning traffic send work.
*Dec 16 06:06:16:403 2024 SW-CORE PORTAL/7/EVENT: Send packet thread message cache timer callback : cnt 1.
*Dec 16 06:06:16:403 2024 SW-CORE PORTAL/7/EVENT: Send packet thread begins processing queue message.
*Dec 16 06:06:16:403 2024 SW-CORE PORTAL/7/EVENT: Send packet thread list is not empty.
解决方法
开启portal用户漫游功能,聚合口开启portal roaming enable功能后问题解决。
