Print
知
【MVS】F5 BIG-IP LTM HTTP XFF头插入配置说明
5天前 发表
问题描述
解决方法
F5 BIG-IP LTM虚服务配置SNAT时,客户端真实的源地址转换为F5设备上配置的地址,导致后端服务器无法获取真实的客户端地址,无法满足溯源等安全侧要求。可以在HTTP请求报文头中插入X-Forwarded-For字段来实现溯源功能,具体操作如下。
Enable the Insert X-Forwarded-For option in the HTTP profile
To configure the BIG-IP system to insert the original client IP address in an X-Forwarded-For HTTP header, perform the following procedure:
  1. Log in to the Configuration utility.
  2. Go to Local Traffic > Profiles.
  3. For Services, select HTTP.
  4. Select Create.
  5. Enter a name for the HTTP profile.
  6. Select the Insert X-Forwarded-For check box.
    Note: Older versions of BIG-IP software may display the option as Insert XForwarded For instead of Insert X-Forwarded-For.
  7. For Insert X-Forwarded-For, select Enabled.
  8. Select Finished.
    You must now associate the new HTTP profile with the virtual server.
实际操作效果如下:
  • 地址转换前
  • SNAT地址转换后
