Print
WX3510H特斯拉终端无线连接报错
2025-02-25 发表
问题描述
现场特斯拉汽车连接室外ap异常报错
过程分析
1、查看配置无异常
wlan service-template 1
 ssid XXX
 akm mode psk
 preshared-key pass-phrase cipher $c$3$CSFchpo6tYoYHAlu56K2sfNPNdp1W3PHdm7/BSPJ
 cipher-suite ccmp
 security-ie rsn
 service-template enable
wlan ap
Ombra
model WA6620X
serial-id 219801A2XXXXXXX
firmware-upgrade disable
vlan 1
radio 1
radio enable
service-template 1 vlan-group a
service-template 2 vlan 255
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
2、收集debug信息,报错报“Failed to access client because this radio need load balance.”
解决方法
根据debug的报错,关闭wlan radio-load-balance overload-5g ssid-hide enable后,终端可以正常接入
