Print
知
某局点WX5540H 远程portal无感知终端点击下线后依旧在线问题处理经验案例
2025-02-26 发表
问题描述
AC结合IMC做远程portal无感知,发现终端点击下线后依旧在线:
查看用户:
过程分析
配置未发现异常,也没有发现类似版本问题,开启debugging portal all和debugging radius all,手动在终端认证页面点击下线的流程如下:
*Jan  5 15:08:15:424 2024 H3C_AC01 PORTAL/7/EVENT: User-SM[172.X.X.X]: Received accounting-off response.
*Jan  5 15:08:15:424 2024 H3C_AC01 PORTAL/7/FSM: User-SM[172.X.X.X]: Begin to run.
*Jan  5 15:08:15:424 2024 H3C_AC01 PORTAL/7/FSM: User-SM [172.X.X.X]: State changed from Offline_Waiting_Acctoff to Done.
*Jan  5 15:08:15:424 2024 H3C_AC01 PORTAL/7/EVENT: User-SM[172.X.X.X]: Stopped User-SM timer.
*Jan  5 15:08:15:424 2024 H3C_AC01 PORTAL/7/FSM: User-SM[172.X.X.X]: User was destroyed.                       //手动在终端的认证页面点击下线,终端下线成功
Portal sent 46 bytes of packet: Type=ack_logout(6), ErrCode=0, IP=172.X.X.X                         //下线成功,AC向服务器发送终端下线报文
*Jan  5 15:08:15:425 2024 H3C_AC01 PORTAL/7/PACKET:
[ 11 SESSIONID           ] [  8] [XXXX-XXXX-XXXX]
 此时终端虽然下线了但是wifi并没有断开,终端自身的某些行为又触发了无感知认证的流程:
*Jan  5 15:08:15:542 2024 H3C_AC01 PORTAL/7/MAC-trigger:                                   //触发无感知流程
    MAC-trigger rule:
    InterfaceL3      = WLAN-BSS1/0/103
    InterfaceL2      = WLAN-BSS1/0/103
    VLAN             = 303
    SrcMAC           = XXXX-XXXX-XXXX
    SrcIP            = 172.X.X.X
*Jan  5 15:08:15:542 2024 H3C_AC01 PORTAL/7/MAC-trigger Event: Notify portal daemon new MAC-trigger entry successfully, SrcIP=172.X.X.X, SrcMAC=XXXX-XXXX-XXXX.
*Jan  5 15:08:15:542 2024 H3C_AC01 PORTAL/7/RULE:
 [Inbound] execute full rule match, { MatchRes = [Rule2-Deny] }
IfName = WLAN-BSS1/0/103, PortName = WLAN-BSS1/0/103, Vlan = 303, SrcMAC = XXXX-XXXX-XXXX,
 SrcIP = 172.X.X.X, DstIP = 40.X.X.X
 *Jan  5 15:08:15:543 2024 H3C_AC01 PORTAL/7/MAC-trigger Event: Received MAC overflow event, MAC=XXXX-XXXX-XXXX.
*Jan  5 15:08:15:544 2024 H3C_AC01 PORTAL/7/EVENT: Success to get ssid by user mac, ssid:Client-Portal, user MAC:XX-XX-XX-XX-XX-XX.
*Jan  5 15:08:15:544 2024 H3C_AC01 PORTAL/7/PACKET:
Portal sent 55 bytes of packet: Type=req_macbind_info(48), ErrCode=0, IP=172.X.X.X             //AC向服务器发送mac绑定查询报文
 *Jan  5 15:08:15:545 2024 H3C_AC01 PORTAL/7/MAC-trigger Event: MAC entry(XXXX-XXXX-XXXX) state changed from DEFAULT to WAIT, user IP = 172.X.X.X.
*Jan  5 15:08:15:546 2024 H3C_AC01 PORTAL/7/EVENT: Success to get info from wlan snooping, vlan:303. mac:XXXX-XXXX-XXXX,userip:172.X.X.X
*Jan  5 15:08:15:546 2024 H3C_AC01 PORTAL/7/EVENT: Success to get ifindex(1926) and vlan(303) from IPCIM, user IP=172.X.X.X,MAC=XXXX-XXXX-XXXX
*Jan  5 15:08:15:546 2024 H3C_AC01 PORTAL/7/PACKET:
Portal received 16 bytes of packet: Type=ack_macbind_info(49), ErrCode=0, IP=172.X.X.X                     // 服务器返回mac查询结果  ErrCode等于0表示该MAC已在服务器绑定,可以走无感知上线
 *Jan  5 15:08:15:546 2024 H3C_AC01 PORTAL/7/MAC-trigger Event: MAC entry(XXXX-XXXX-XXXX) state changed from WAIT to BIND. user IP=172.X.X.X.           //无感知上线成功
解决方法
现场AC结合IMC做的Portal无感知认证点了下线之后还在线并且还能正常上网是正常的,因为portal虽然下线了但是无线并没有断开,终端的一些行为会再次触发无感知上线并正常上网
所以现场portal无感知场景终端上点击下线不能使终端无法上网,可以从IMC上强制终端下线,IMC上应该可以同时清除无感知表项,终端再次上线就需要认证才能上线
