Print
知
某局点S5570S-54S-EI 802.1x逃生不生效
3天前 发表
组网及说明
设备型号和版本:S5570S-54S-EI  Release 1128
问题描述
现场配置802.1x逃生不生效,服务器不可达的时候,用户(1/0/27)无法进入逃生vlan,设备学不到终端的地址。
过程分析
1、  现场设备版本是最新的
2、  接口配置如下:
interface GigabitEthernet1/0/27
port link-mode bridge
port access vlan 601
stp edged-port
dot1x
undo dot1x handshake
dot1x mandatory-domain carizon-domain
dot1x critical vlan 601
mac-authentication
mac-authentication domain carizon-domain
mac-authentication critical vlan 601
3、  服务器状态
  ===============display radius scheme===============
Total 2 RADIUS schemes
RADIUS scheme name: carizon-radius
  Index: 0
  Primary authentication server:
    Host name: Not Configured
    IP   : x.x.x.44                               Port: 1812
    VPN  : Not configured
    State: Blocked
    Most recent blocked period: 2024/11/02 22:57:39 - now
    Test profile: taosheng
      Probe username: admin
      Probe interval: 1 minutes
    Weight: 0
  Primary accounting server:
    IP   :  x.x.x.44                                Port: 1813
    State: Active (duration: 0 weeks, 0 days, 1 hours, 12 minutes, 1 seconds)
    Weight: 0
  Accounting-On function                     : Disabled
    extended function                        : Disabled
    retransmission times                     : 50
    retransmission interval(seconds)         : 3
  Timeout Interval(seconds)                  : 3
  Retransmission Times                       : 3
  Retransmission Times for Accounting Update : 5
  Server Quiet Period(minutes)               : 5
  Realtime Accounting Interval(seconds)      : 720
  Stop-accounting packets buffering          : Enabled
    Retransmission times                     : 500
  NAS IP Address                             : x.x.x.2
  User Name Format                           : without-domain
  Data flow unit                             : Byte
  Packet unit                                : One
  Attribute 15 check-mode                    : Strict
  Attribute 25                               : Standard
  Attribute Remanent-Volume unit             : Kilo
  server-load-sharing                        : Disabled
  Attribute 31 MAC format                    : HH-HH-HH-HH-HH-HH
  Stop-accounting packets send-force         : Disabled
  Reauthentication server selection          : Inherit
  Attribute 218 of vendor ID 25506           : DHCP-Option 61
                                               Format 1 (1-byte Type field)
4、看debug信息确实存在服务器不可达及认证失败的信息
*RADIUS/7/EVENT: Found request context, dstIP: x.x.x.x; dstPort: 1812; VPN instance: --(public); socketfd: 94; pktID:23.
*RADIUS/7/EVENT: Retransmitting request packet, currentTries: 3, maxTries: 3.
*DOT1X/7/EVENT: User aging timer expired: UserMAC=xxxx-xxxx-xx75, VLANID=601, Interface=GigabitEthernet1/0/27.
*DOT1X/7/EVENT: BE is in Initialize state: UserMAC=xxxx-xxxx-xx75, VLANID=601, Interface=GigabitEthernet1/0/27.
*DOT1X/7/EVENT: Interface GigabitEthernet1/0/27 received Set the port authorization status to unauthorized event.
解决方法
后经产品线定位:加入1x  的critical vlan要么是mac-vlan  enable(需要配置成hybrid口),要么是port-based模式,现场需要同时启用mac 和1x认证的,那就只能是改hybrid口了。
现场改成hybrid口,配置mac-vlan enable之后就ok了。
