Print
知
[MVS]Oracle Exadata X8存储主动更换硬盘
10小时前 发表
问题描述
硬盘在系统日志提示有error,但ASM多次尝试修复,影响数据库稳定,主动更换硬盘。
过程分析
查看存储节点系统日志,多次提示硬盘error,但ASM接管重新挂载硬盘后,恢复正常。
解决方法
环境:Oracle Exadata X8
exadata system info: 19.2.13.0.0.200428
OS: oracle linux 7.7
1.检查硬盘号;
查看硬盘插槽,硬盘上承载的grid disk等;
# cellcli list diskmap
或:# cellcli list physicaldisk
或  # cellcli –e "list diskmap" | grep 'X:Y'
2.删除硬盘
2.1. 如Oracle Exadata System Software release 21.2.0,则如下命令将自动删除硬盘并管理冗余性;
CellCLI> alter physicaldisk X:Y drop for replacement maintain redundancy
注意:等命令执行结束才能下一步;
2.2:如Oracle Exadata System Software release 小于21.2.0,则需要顺序执行如下命令:
1)、.删除对应grid disk;
SQL> ALTER DISKGROUP diskgroup_name DROP DISK asm_disk_name;
备注:如删除griddisk报错
ORA-15032: not all alterations performed
ORA-15410: Disks in disk group OCRVT do not have equal size.
或者
ORA-15411: Failure groups in disk group OCRVT have different number of disks.
解决方案:
动态修改这两个隐藏参数解决限制副本数问题:
alter system set "_asm_disable_failgroup_size_checking"=true;
alter system set "_asm_disable_dangerous_failgroup_checking"=true;
2) . 等待磁盘rebalance操作完成,查询:select  * from v$asm_operation;
3). cell中删除物理硬盘
如防止超时退出,可后台执行:# cellcli -e "alter physicaldisk X:Y drop for replacement" &
备注:
  • ϒ⁄ cell alert log  cell中查看进度, 日志路径:/opt/oracle/cell/log/diag/asm/cell/<cell_name>/trace/alert.log
  • ϒ⁄ 查看总体脏块刷新速度,最终是否结束以日志提示为准。CellCLI> list metriccurrent attributes name,metricvalue where name like 'FC_BY_DIRTY';
  • ϒ⁄ exadata 19.2版本可能会hang,  但本次测试解决方案效果不明显;Exadata ALTER PHYSICALDISK N:N DROP FOR REPLACEMENT is hung (Doc ID 2574663.1)
  • 14T HDD硬盘删除耗时5小时左右;
3.Ensure that the blue OK to Remove LED on the disk is lit before removing the disk.
硬盘删除成功后,# cellcli list physicaldisk 查看磁盘已删除;
4.Replace the new hard disk.
手动更换硬盘后,系统自动按原配置加到ASM 磁盘组中;
5.verify the LUN, cell disk and grid disk associated with the hard disk were created.
CellCLI> alter cell validate configuration     》》》自动升级固件;不能有mdadm错误;
CellCLI> list lun lun_name
CellCLI> list celldisk where lun=lun_name
CellCLI> list griddisk where celldisk=celldisk_name
CellCLI> LIST PHYSICALDISK  detail
6.硬盘更换完成后将ASM隐藏参数修改回来;
alter system set "_asm_disable_failgroup_size_checking"=false;
alter system set "_asm_disable_dangerous_failgroup_checking"=false;
7.Verify the grid disk was added to the Oracle ASM disk groups.
The following query should return no rows.
SQL> SELECT path,header_status FROM v$asm_disk WHERE group_number=0;
The following query shows whether all the failure groups have the same number of disks:
SQL> select * from v$asm_disk;
参考:
官方文档:3.3.5 Replacing a Hard Disk Proactively
https://docs.oracle.com/en/engineered-systems/exadata-database-machine/dbmmn/replacing-hard-disk-proactively.html
Oracle Exadata换盘操作-Replacing a Hard Disk Proactively
https://blog.csdn.net/xxzhaobb/article/details/126389951
Exadata存储节点,主动更换磁盘
https://www.cnblogs.com/missyou-shiyh/p/18581627
MOS:
How to Replace a Hard Drive in an Exadata Storage Cell Server (Predictive Failure) (Doc ID 1390836)
