Print
知
某局点S5130S-52S-PWR-HI|交换机下接的话机会重启
2025-03-24 发表
组网及说明
设备型号和版本:S5130S-52S-PWR-HI Release 6343P08
问题描述
现场反馈使用5130交换机替换3600交换机后,部分话机在接完电话后会重启,日志也有告警
%Oct 14 11:31:44:639 2024 BDC-CCU-AS-HC5130-01_20F POE/1/PSE_PORT_ON_OFF_CHANGE: Trap <pethPsePortOnOffNotification>: PSE 4, IfIndex 4, Detection Status 6.
%Oct 14 11:31:51:815 2024 BDC-CCU-AS-HC5130-01_20F IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/4 changed to up.
%Oct 14 11:31:51:822 2024 BDC-CCU-AS-HC5130-01_20F IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/4 changed to up.
%Oct 14 11:31:53:390 2024 BDC-CCU-AS-HC5130-01_20F POE/1/PSE_PORT_ON_OFF_CHANGE: Trap <pethPsePortOnOffNotification>: PSE 4, IfIndex 4, Detection Status 3.
过程分析
1、仅交换机端口供电,交换机配置POE非标监测和强制供电,故障依旧
2、仅外接电源供电,交换机关闭POE供电功能,插上话机自带的电源适配器,正常
3、查看设备供电情况,设备还剩1585.3(W),如果怀疑是功率不足,概率不大
===============display poe device===============
Slot  1:
 PSE ID    Slot No.  SSlot No. PortNum   MaxPower(W)    State   Model
 4         1         0         48        1680.0         On      LSPPSE48B
  ===============display poe interface===============
 Interface    PoE       Priority  CurPower  Oper      IEEE  Detection
                                  (W)                 Class Status
 GE1/0/1      Enabled   Low       2.7       On        1     Delivering Power
 GE1/0/2      Enabled   Low       2.7       On        1     Delivering Power
 GE1/0/3      Enabled   Low       2.8       On        1     Delivering Power
 GE1/0/4      Enabled   Low       2.8       On        1     Delivering Power
 GE1/0/5      Enabled   Low       2.7       On        1     Delivering Power
 GE1/0/6      Enabled   Low       2.7       On        1     Delivering Power
 GE1/0/7      Enabled   Low       2.6       On        1     Delivering Power
 GE1/0/8      Enabled   Low       2.7       On        1     Delivering Power
 GE1/0/9      Enabled   Low       2.8       On        1     Delivering Power
 GE1/0/10     Enabled   Low       2.7       On        1     Delivering Power
 GE1/0/11     Enabled   Low       2.7       On        1     Delivering Power
 GE1/0/12     Enabled   Low       0.0       Off       0     Searching
 GE1/0/13     Enabled   Low       0.0       Off       0     Searching
 GE1/0/14     Enabled   Low       0.0       Off       0     Searching
 GE1/0/15     Enabled   Low       0.0       Off       0     Searching
 GE1/0/16     Enabled   Low       0.0       Off       0     Searching
 GE1/0/17     Enabled   Low       2.7       On        1     Delivering Power
 GE1/0/18     Enabled   Low       2.7       On        1     Delivering Power
 GE1/0/19     Enabled   Low       0.0       Off       0     Searching
 GE1/0/20     Enabled   Low       2.8       On        1     Delivering Power
 GE1/0/21     Enabled   Low       2.8       On        1     Delivering Power
 GE1/0/22     Enabled   Low       0.0       Off       0     Searching
 GE1/0/23     Enabled   Low       0.0       Off       0     Searching
 GE1/0/24     Enabled   Low       0.0       Off       0     Searching
 GE1/0/25     Enabled   Low       0.0       Off       0     Searching
 GE1/0/26     Enabled   Low       0.0       Off       0     Searching
 GE1/0/27     Enabled   Low       3.0       On        1     Delivering Power
 GE1/0/28     Enabled   Low       3.0       On        1     Delivering Power
 GE1/0/29     Enabled   Low       2.9       On        1     Delivering Power
 GE1/0/30     Enabled   Low       3.0       On        1     Delivering Power
 GE1/0/31     Enabled   Low       2.4       On        1     Delivering Power
 GE1/0/32     Enabled   Low       2.8       On        1     Delivering Power
 GE1/0/33     Enabled   Low       3.2       On        1     Delivering Power
 GE1/0/34     Enabled   Low       0.0       Off       0     Searching
 GE1/0/35     Enabled   Low       0.0       Off       0     Searching
 GE1/0/36     Enabled   Low       2.7       On        1     Delivering Power
 GE1/0/37     Enabled   Low       0.0       Off       0     Searching
 GE1/0/38     Enabled   Low       2.4       On        1     Delivering Power
 GE1/0/39     Enabled   Low       3.0       On        1     Delivering Power
 GE1/0/40     Enabled   Low       2.8       On        1     Delivering Power
 GE1/0/41     Enabled   Low       2.8       On        1     Delivering Power
 GE1/0/42     Enabled   Low       2.9       On        1     Delivering Power
 GE1/0/43     Enabled   Low       2.8       On        1     Delivering Power
 GE1/0/44     Enabled   Low       2.9       On        1     Delivering Power
 GE1/0/45     Enabled   Low       2.7       On        1     Delivering Power
 GE1/0/46     Enabled   Low       2.8       On        1     Delivering Power
 GE1/0/47     Enabled   Low       2.8       On        1     Delivering Power
 GE1/0/48     Enabled   Low       2.9       On        1     Delivering Power
   ---  On State Ports: 34; Used: 94.7(W); Remaining: 1585.3(W)  ---
4、现场交换机和话机通过配线架连接,从交换机到配线架的跳线已经更换。福禄克测试通过
5、产品线分析诊断信息,发现port4、27、41口有POE过电流掉电记录,与现场反馈现象(5130-1的4、27、41口连IP话机存在反复重启)一致。
       i_s_cnt         p_d_cnt         o_cnt           s_cnt           m_a_cnt
port0   213             0               0               0               0
port1   224             0               0               0               0
port2   233             0               0               0               0
port3   578             0               3               0               1
port4   260             0               0               0               0
port5   272             0               0               0               0
port6   293             0               0               0               0
port7   306             0               0               0               0
port8   313             0               0               0               0
port9   329             0               0               0               0
port10  671             0               0               0               1
port11  190554          0               0               0               0
port12  188925          0               0               0               0
port13  187631          0               0               0               0
port14  188933          0               0               0               0
port15  187608          0               0               0               0
port16  482             0               0               0               0
port17  489             0               0               0               0
port18  189416          0               0               0               0
port19  515             0               0               0               0
port20  520             0               0               0               0
port21  189642          0               0               0               0
port22  189589          0               0               0               0
port23  189585          0               0               0               0
port24  186807          0               0               0               0
port25  186772          0               0               0               0
port26  537             0               1               0               0
port27  809             0               0               0               4
port28  554             0               0               0               0
port29  1958            0               0               0               3
port30  562             0               0               0               0
port31  568             0               0               0               0
port32  579             0               0               0               0
port33  189000          0               0               0               0
port34  189010          0               0               0               0
port35  586             0               0               0               0
port36  190011          0               0               0               0
port37  596             0               0               0               0
port38  614             0               0               0               0
port39  625             0               0               0               0
port40  808             0               8               0               1
port41  639             0               0               0               0
port42  648             0               0               0               0
port43  660             0               0               0               0
port44  666             0               0               0               0
port45  680             0               0               0               0
port46  689             0               0               0               0
port47  690             0               0               0               0
因此POE震荡原因:客户处话机为Class1终端,与交换机分级结果也一致(如下诊断信息高亮部分)。根据IEEE标准Class1供电功率最大为4W,如终端电话功耗超过4W就会触发交换机侧过流掉电,掉电后交换机又会重新检测分级上电,因此会出现客户处的POE震荡。
                                               (W)                      Class     Status
解决方法
将端口最大功率强制到25W,避免部分电话功率超过4W触发掉电。
震荡端口下配置命令行 poe max-power 25000
