Print
知
ADWAN控制器告警链路丢包率为100%的经验案例
11小时前 发表
问题描述
如下图所示,链路的丢包率为100%
过程分析
1.首先在控制器上【物理网络-链路-链路管理】页面确认质量探测下发结果都为成功,若失败,可以点击重新下发
2.在设备上检查nqa的配置是否正常下发(注意区分server端和client端)
·            Server端(P1):
<P1> display current-configuration | inc nqa
 nqa server enable
 nqa server udp-echo ipv6 72::112:1:1 10000 high-performance-mode
·            Client端(P2):
<P2> display current-configuration
nqa entry admin f005ed9c43954a8c89a948d64a0b4d3f
 type udp-jitter
  destination ipv6 72::112:1:1
  destination port 10000
  frequency 3000
  high-performance-mode enable
  probe packet-interval 80
  probe packet-number 100
  probe packet-timeout 1600
  source ipv6 72::112:1:2
nqa schedule admin f005ed9c43954a8c89a948d64a0b4d3f start-time now lifetime forever
3.若发现设备上缺少nqa的配置,可以审计设备的配置看看是否有控制器比设备多的配置,如下图所示,存在未下发的配置,需要点击数据同步
4. 确认设备配置正常后,在设备上通过display nqa statistics查看结果,如果丢包率数据就是100%,需要找设备侧排查具体原因
[MSR5620]display nqa statistics
NQA entry (admin admin, tag e30d17b16a8b4f1088fed968c4cacba2) test statistics:
  NO. : 3638
    Start time: 2025-03-13 15:28:28.5
    Life time: 1979 seconds
    Send operation times: 4950           Receive response times: 0
    Min/Max/Average round trip time: 0/0/0
    Square-Sum of round trip time: 0
  Extended results:
    Packet loss ratio: 100.0%
    Failures due to timeout: 4950
    Failures due to internal error: 0
    Failures due to other errors: 0
    Packets out of sequence: 0
    Packets arrived late: 0
解决方法
现场在client端查看有的链路丢包率正常,有的链路丢包率为100%。设备侧查看对端设备的网板故障,更换后丢包率恢复。
