Print
知
S5570S-54S-PWR-EI poe供电失败
2025-10-16 发表
组网及说明
不涉及
告警信息
不涉及
问题描述
S5570S-54S-PWR-EI-A-1125设备所有接口都供不上电,
GE1/0/9      Enabled   Low       0.0       Power-deny0     PD Disconnected
 GE1/0/10     Enabled   Low       0.0       Off       0     Searching
 GE1/0/11     Enabled   Low       0.0       Power-deny0     PD Disconnected
 GE1/0/12     Enabled   Low       0.0       Power-deny0     PD Disconnected
 GE1/0/13     Enabled   Low       0.0       Power-deny0     PD Disconnected
 GE1/0/14     Enabled   Low       0.0       Power-deny0     PD Disconnected
过程分析
看pse显示没功率可用
  ===============display poe pse===============
 PSE ID                           : 4
Slot No.                         : 1
SSlot No.                        : 0
PSE Model                        : LSPPSE48A
PSE Status                       : Enabled
PSE Fast Power Supply            : Disabled
Power Priority                   : Low
Current Power                    : 0.0      W
Average Power                    : 0.0      W
Peak Power                       : 0.0      W
Max Power                        : 0.0      W
Remaining Guaranteed Power       : 0.0      W
PSE CPLD Version                 : -
 PSE Software Version             : 1082
PSE Hardware Version             : 312
 PSE Legacy PD Detection          : Disabled
Power Utilization Threshold      : 80
PD Power Policy                  : Disabled
PD Disconnect-Detection Mode     : DC
PD High Inrush                   : Disabled
R1125没有适配1300W 电源
解决方法
升级到R1128 版本
