Print
知
MSR2600-15-X1 下联口插终端设备Pping 1472 -f 异常问题
2025-11-12 发表
组网及说明
问题描述
L2VPN 组网,基本配置如下,当前客户测试ping 测试超过1472 报文不通。
对端ping 测试:
本端ping 测试:
过程分析
配置梳理
 router id 100.66.19.30
 mpls lsr-id 100.66.19.30
 mpls load-sharing mode per-packet
mpls ldp
tunnel-policy 1
 select-seq lsp load-balance-number 2
 l2vpn enable
vsi test
 mtu 1600
 pwsignaling ldp
  peer 100.66.19.2 pw-id 500 tunnel-policy 1
interface LoopBack100
 ip address 100.66.19.30 255.255.255.255
interface GigabitEthernet0/0
 port link-mode route
 mtu 1600
 xconnect vsi test
interface GigabitEthernet0/11
 description To-Customer-Line1
 mtu 1600
 ip address 192.168.10.2 255.255.255.0
 mpls enable
 mpls ldp enable
interface GigabitEthernet0/12
 description To-Customer-Line2
 mtu 1600
 ip address 192.168.20.2 255.255.255.0
 mpls enable
 mpls ldp enable
bgp 100
 peer 100.66.19.2 as-number 100
 peer 100.66.19.2 connect-interface LoopBack100
 address-family l2vpn
  peer 100.66.19.2 enable
 router id 100.66.19.2
 mpls lsr-id 100.66.19.2
 l2vpn enable
vsi test
 mtu 1600
 pwsignaling ldp
  peer 100.66.19.30 pw-id 500 tunnel-policy 1
tunnel-policy 1
 mtu 1600
 xconnect vsi test
 description To-Switch
 mtu 1600
 mpls mtu 1600
 mpls ldp enable
 ip address 100.66.19.2 255.255.255.255
interface GigabitEthernet0/1.3101
 description Line1
 traffic-statistic enable
 mtu 1600
 ip address 192.168.10.1 255.255.255.0
 mpls enable
 mpls mtu 1600
 mpls ldp enable
 vlan-type dot1q vid 3101
interface GigabitEthernet0/1.3102
 description Line2
 mtu 1600
 ip address 192.168.20.1 255.255.255.0
 mpls enable
 mpls mtu 1600
 mpls ldp enable
 vlan-type dot1q vid 3102
bgp 100
 peer 100.66.19.30 as-number 100
 peer 100.66.19.30 connect-interface LoopBack100
  peer 100.66.19.30 enable
镜像分析VPLS 的公网链路也没有发包,模式现网环境测试现象一致。
本地使用wirshark 抓包,发现终端发不出超过1472 -f 不分片报文
解决方法
终端不指定-F 参数
