Print
知
组播组成员离组后其他组播成员也收不到流量
3小时前 发表
问题描述
交换机做业务网关+服务器接入,开启组播pim、igmp、igmp-snoopong。下挂同一网段多个接收者,加入同一个组播组。任意接收者退组时,其它接收者就收不到流量了
过程分析
现场采集的debug信息:
收到离开:
*Dec 22 18:58:39:551 2025 S6600_H35_H36 IGMP/7/REPORT: Received IGMPv3 report on interface Vlan-interface9( x.x.27.254) from x.x.27.14 (G161453)
*Dec 22 18:58:39:551 2025 S6600_H35_H36 IGMP/7/REPORT: Process TO_IN packet for EXCLUDE group(x.10.0.50) on interface Vlan-interface9( x.x.27.254), uiL3vni:(4294967295) (G117359)
*Dec 22 18:58:39:551 2025 S6600_H35_H36 IGMP/7/TIMER: Set group aging timer for group(x.10.0.50) on interface Vlan-interface9( x.x.27.254) to 2s (G113937)
发送特定组查询报文:
*Dec 22 18:58:39:551 2025 S6600_H35_H36 IGMP/7/QUERY SEND: Send IGMP version 3 group specific query without S bit on Vlan-interface9( x.x.27.254) for group x.10.0.50 (G14395)
*Dec 22 18:58:39:551 2025 S6600_H35_H36 IGMP/7/TIMER: Set group retransmit timer for group(x.10.0.50) on interface Vlan-interface9( x.x.27.254) to 1s (G113840)
*Dec 22 18:58:39:551 2025 S6600_H35_H36 MCS/7/PACKET: Receive IGMP query packet from local on VLAN 9. (MCS367411)
*Dec 22 18:58:39:551 2025 S6600_H35_H36 MCS/7/SYNC: Main slot forward the IGMP packet to other slots.
*Dec 22 18:58:39:551 2025 S6600_H35_H36 MCS/7/PACKET: Forward the specific group query packet with group x.10.0.50 on VLAN 9. (MCS364471)
*Dec 22 18:58:39:551 2025 S6600_H35_H36 MCS/7/PACKET: Succeed in forwarding packet to port Ten-GigabitEthernet1/0/1 on VLAN 9. (MCS152179)
*Dec 22 18:58:39:552 2025 S6600_H35_H36 MCS/7/PACKET: Succeed in forwarding packet to port Ten-GigabitEthernet1/0/2 on VLAN 9. (MCS152179)
*Dec 22 18:58:38:901 2025 S6600_H35_H36 MCS/7/SYNC: -Slot=2; Receive IGMP or PIM packet from another slot.
*Dec 22 18:58:39:552 2025 S6600_H35_H36 MCS/7/PACKET: Succeed in forwarding packet to port Ten-GigabitEthernet1/0/3 on VLAN 9. (MCS152179)
*Dec 22 18:58:38:901 2025 S6600_H35_H36 MCS/7/PACKET: -Slot=2; Forward the IGMP membership packet which destination IP address is 224.0.0.22 and source IP address is x.x.27.14 on VLAN 9. (MCS364778)
*Dec 22 18:58:38:902 2025 S6600_H35_H36 MCS/7/ERROR: -Slot=2; ! Get DRGroup 0 of ifindex 8. (MCS0420593)
*Dec 22 18:58:39:552 2025 S6600_H35_H36 MCS/7/PACKET: Succeed in forwarding packet to port Ten-GigabitEthernet1/0/8 on VLAN 9. (MCS152179)
*Dec 22 18:58:39:552 2025 S6600_H35_H36 MCS/7/PACKET: Succeed in forwarding packet to port Ten-GigabitEthernet1/0/9 on VLAN 9. (MCS152179)
*Dec 22 18:58:39:552 2025 S6600_H35_H36 MCS/7/PACKET: Succeed in forwarding packet to port Ten-GigabitEthernet1/0/11 on VLAN 9. (MCS152179)
*Dec 22 18:58:39:553 2025 S6600_H35_H36 MCS/7/PACKET: Succeed in forwarding packet to port Ten-GigabitEthernet1/0/13 on VLAN 9. (MCS152179)
*Dec 22 18:58:38:903 2025 S6600_H35_H36 MCS/7/SYNC: -Slot=2; Receive local IGMP or PIM packet from main slot.
*Dec 22 18:58:38:903 2025 S6600_H35_H36 MCS/7/PACKET: -Slot=2; Receive query packet from main slot.
*Dec 22 18:58:38:903 2025 S6600_H35_H36 MCS/7/PACKET: -Slot=2; Forward the specific group query packet with group x.10.0.50 on VLAN 9. (MCS364471)
*Dec 22 18:58:38:904 2025 S6600_H35_H36 MCS/7/PACKET: -Slot=2; Succeed in forwarding packet to port Ten-GigabitEthernet2/0/10 on VLAN 9. (MCS152179)
*Dec 22 18:58:40:182 2025 S6600_H35_H36 MCS/7/PACKET: Receive IGMPv3 report packet from port Ten-GigabitEthernet1/0/8 on VLAN 9. (MCS363126)  //这里实际上还是前面的离开报文。
再次发送特定组查询报文:
*Dec 22 18:58:40:559 2025 S6600_H35_H36 IGMP/7/TIMER: Group retransmit timer for group(x.10.0.50) expired (G112331)
*Dec 22 18:58:40:559 2025 S6600_H35_H36 IGMP/7/QUERY SEND: Send IGMP version 3 group specific query without S bit on Vlan-interface9( x.x.27.254) for group x.10.0.50 (G14395)
*Dec 22 18:58:40:559 2025 S6600_H35_H36 MCS/7/PACKET: Receive IGMP query packet from local on VLAN 9. (MCS367411)
*Dec 22 18:58:40:560 2025 S6600_H35_H36 MCS/7/SYNC: Main slot forward the IGMP packet to other slots.
*Dec 22 18:58:40:560 2025 S6600_H35_H36 MCS/7/PACKET: Forward the specific group query packet with group x.10.0.50 on VLAN 9. (MCS364471)
*Dec 22 18:58:40:560 2025 S6600_H35_H36 MCS/7/PACKET: Succeed in forwarding packet to port Ten-GigabitEthernet1/0/1 on VLAN 9. (MCS152179)
*Dec 22 18:58:40:560 2025 S6600_H35_H36 MCS/7/PACKET: Succeed in forwarding packet to port Ten-GigabitEthernet1/0/2 on VLAN 9. (MCS152179)
*Dec 22 18:58:40:560 2025 S6600_H35_H36 MCS/7/PACKET: Succeed in forwarding packet to port Ten-GigabitEthernet1/0/3 on VLAN 9. (MCS152179)
*Dec 22 18:58:40:560 2025 S6600_H35_H36 MCS/7/PACKET: Succeed in forwarding packet to port Ten-GigabitEthernet1/0/8 on VLAN 9. (MCS152179)
*Dec 22 18:58:40:560 2025 S6600_H35_H36 MCS/7/PACKET: Succeed in forwarding packet to port Ten-GigabitEthernet1/0/9 on VLAN 9. (MCS152179)
*Dec 22 18:58:40:561 2025 S6600_H35_H36 MCS/7/PACKET: Succeed in forwarding packet to port Ten-GigabitEthernet1/0/11 on VLAN 9. (MCS152179)
*Dec 22 18:58:40:561 2025 S6600_H35_H36 MCS/7/PACKET: Succeed in forwarding packet to port Ten-GigabitEthernet1/0/13 on VLAN 9. (MCS152179)
*Dec 22 18:58:39:911 2025 S6600_H35_H36 MCS/7/SYNC: -Slot=2; Receive local IGMP or PIM packet from main slot.
*Dec 22 18:58:39:912 2025 S6600_H35_H36 MCS/7/PACKET: -Slot=2; Receive query packet from main slot.
*Dec 22 18:58:39:912 2025 S6600_H35_H36 MCS/7/PACKET: -Slot=2; Forward the specific group query packet with group x.10.0.50 on VLAN 9. (MCS364471)
*Dec 22 18:58:39:912 2025 S6600_H35_H36 MCS/7/PACKET: -Slot=2; Succeed in forwarding packet to port Ten-GigabitEthernet2/0/10 on VLAN 9. (MCS152179)
没有收到report报文,组播组老化删除:
*Dec 22 18:58:41:559 2025 S6600_H35_H36 IGMP/7/TIMER: Group exclude aging timer for group(x.10.0.50) expired (G113334)
*Dec 22 18:58:41:559 2025 S6600_H35_H36 IGMP/7/EVENT: Change mode from EXCLUDE to INCLUDE for group(x.10.0.50) on interface Vlan-interface9( x.x.27.254) (G112884)
*Dec 22 18:58:41:559 2025 S6600_H35_H36 IGMP/7/EVENT: Send PRUNE for (0.0.0.0,x.10.0.50) on interface Vlan-interface9( x.x.27.254) to MRIB (G097755)
*Dec 22 18:58:41:559 2025 S6600_H35_H36 IGMP/7/EVENT: Delete group(x.10.0.50) on interface Vlan-interface9( x.x.27.254) (G11735)
设备收到离开报文后,三层igmp发送了特定组查询报文,但是服务器没有回应report报文,导致三层igmp组播组老化。
所以三层组播转发表删除了Vlan-interface 9出接口,导致vlan  9下的其他二层口也无法转发流量。
解决方法
排查服务器为什么不会回应特定查询组的report报文
