Print
S5590异常重启
2026-03-19 发表
组网及说明
设备:S5590-28S8XC-EI Version 7.1.070, Release 8307P10
问题描述
异常重启
Slot 1:
Uptime is 2 weeks,2 days,0 hours,54 minutes
BOARD TYPE:         S5590-28S8XC-EI
DRAM:               2048M bytes
FLASH:              3687M bytes
PCB Version:        VER.A
Bootrom Version:    114
CPLD 1 Version:     002
CPLD 2 Version:     002
Power CPLD Version: None
PowChip Version:    None
Release Version:    S5590EI-8307P10
Patch Version:      R8307P10HS03
Reboot Cause:       KernelAbnormalReboot
过程分析
  ===============display kernel exception 20 verbose slot 1 ===============
--------------------- Exception record 1 ---------------------
Description           : Soft watchdog detected hard LOCKUP on cpu 1 ----CPU1在中断中执行时间过长,触发软件看门狗 狗叫重启
Recorded at           : 2011-01-10  21:29:22.775999
Occurred at           : 2011-01-10  21:29:22.775999
Instruction address   : 0xffffff80804b9c7c
Thread                : BMDT (TID: 5529)
Context               : irq context
Slot                  : 1
Cpu                   : 0
VCPU ID               : 1
Kernel module info    : module name (kpatch_system_kernel_HS03_systemko_merge) module address (0xffffff8009bad000)
                        module name (kpatch_ver_2_1) module address (0xffffff8009b98000)
                        module name (kpatch_core) module address (0xffffff8009b89000)
                        module name (system) module address (0xffffff800073a000)
                        module name (addon) module address (0xffffff80006a0000)
============ History interrupt info of slot 1 ============
------------ hard irq trace ------------
on cpu 0:
  irq status: 0
  last irq no: 2
  max irq no: 28
  last enter time: @141176ms
  last  exit time: @141176ms
  max consuming time: 0ms
on cpu 1:
  irq status: 0
  last irq no: 2  ----Cpu1在最后执行的中断类型是2号中断
  max irq no: 2
  ===============interrupt info ===============
           CPU0       CPU1       CPU2       CPU3
  1:          0          0          0          0     GICv3  29 Edge      arch_timer
  2: 3613627106  157412606 3499002895 1826403943     GICv3  30 Edge      arch_timer ---2号中断是系统级架构定时器arch_timer,正常情况下会1ms超时从中断中退出一次,只能是该中断的定时器值发生bit翻转,才有超过28秒不退出的情况,触发watchdog重启。
  6:        795          0          0          0     GICv3  39 Level     uart-pl011
解决方法
根据异常重启记录的信息分析符合一个已知问题,建议升级R8336P11版本解决。
202512010774
问题现场:设备低概率异常重启
产生条件:设备运行中内存发生bit翻转。
