Print
知
某局点S7506X-G设备查看接口命令卡死
2026-03-23 发表
问题描述
故障现象:设备输入查看接口相关的命令会卡死
过程分析
查看日志信息有大量的LIPC信息与STP信息,判断是stp和聚合的进程通信卡住了,是现场设备bagg14的stp状态高频率震荡导致。
%@909876%Feb 28 22:53:35:425 2026 HX LIPC/4/LIPC_STCP_CHECK: -Chassis=2-Slot=1; Data stays in the receive buffer for an over long time. Owner=, VRF=0, MDC=0, local address/port=32768/0, remote address/port=4120/52711.
%@909877%Feb 28 22:53:35:425 2026 HX LIPC/4/LIPC_STCP_CHECK: -Chassis=2-Slot=1; Data stays in the receive buffer for an over long time. Owner=, VRF=0, MDC=0, local address/port=32768/0, remote address/port=4120/51222.
%@909878%Feb 28 22:53:35:425 2026 HX LIPC/4/LIPC_STCP_CHECK: -Chassis=2-Slot=1; Data stays in the receive buffer for an over long time. Owner=laggd, VRF=0, MDC=1, local address/port=4104/27370, remote address/port=4120/1132.
%@909879%Feb 28 22:53:35:425 2026 HX LIPC/4/LIPC_STCP_CHECK: -Chassis=2-Slot=1; Data stays in the receive buffer for an over long time. Owner=stpd, VRF=0, MDC=1, local address/port=4104/20343, remote address/port=4104/10519.
%@909880%Feb 28 22:53:35:425 2026 HX LIPC/4/LIPC_STCP_CHECK: -Chassis=2-Slot=1; Data stays in the receive buffer for an over long time. Owner=laggd, VRF=0, MDC=1, local address/port=4104/20226, remote address/port=4104/10519.
%@909881%Feb 28 22:53:36:888 2026 HX STP/4/STP_DISPUTE: Instance 0's port Bridge-Aggregation14 received an inferior BPDU from a designated port which is in forwarding or learning state. The designated bridge ID contained in the BPDU is 32768.083b-e931-f86d, and the designated port ID contained in the BPDU is 128.23.
%@909882%Feb 28 22:53:36:892 2026 HX STP/6/STP_DISCARDING: Instance 0's port Bridge-Aggregation14 has been set to discarding state.
%@909883%Feb 28 22:53:36:896 2026 HX STP/6/STP_DISPUTE_RESTORATION: Instance 0's port Bridge-Aggregation14 exited the dispute state.
%@909884%Feb 28 22:53:36:904 2026 HX STP/6/STP_FORWARDING: Instance 0's port Bridge-Aggregation14 has been set to forwarding state.
%@909885%Feb 28 22:53:38:888 2026 HX STP/4/STP_DISPUTE: Instance 0's port Bridge-Aggregation14 received an inferior BPDU from a designated port which is in forwarding or learning state. The designated bridge ID contained in the BPDU is 32768.083b-e931-f86d, and the designated port ID contained in the BPDU is 128.23.
%@909886%Feb 28 22:53:38:891 2026 HX STP/6/STP_DISCARDING: Instance 0's port Bridge-Aggregation14 has been set to discarding state.
%@909887%Feb 28 22:53:38:895 2026 HX STP/6/STP_DISPUTE_RESTORATION: Instance 0's port Bridge-Aggregation14 exited the dispute state.
解决方法
现场已重启2框恢复,重启后仍然有stp报错,当前已排查调整bagg14对端设备,解决stp震荡问题。
