S5130S-52P-EI 为接入交换机,配置802.1X认证
4/0/43接口下的终端mac,会通过其他接口学习到。 接口替换测试,故障现象和4/0/43口强相关。
终端e4a8-xxxx-e811正常是接在4/0/43口,
dis mac-address | include e811
e4a8-xxxx-e811 36 Learned GE4/0/43 Y
当接口downup或者终端重启后,此mac地址也会从其他接口(不固定)学到:
1、有此mac地址的mac漂移记录,但结合stp和现场替换接口测试,不存在环路
===============display mac-address mac-move===============
e4a8-xxxx-e811 235 GE3/0/2 GE4/0/43 2026-03-05 16:47:52 2
e4a8-xxxx-e811 235 GE3/0/37 GE4/0/43 2026-03-05 16:43:58 4
2、开启debug dot1x,4/0/43口下的终端e4a8-dfd5-e811重启,当接口up后,会立即从其他接口收到源mac是e4a8-xxxx-e811的eap报文:
%Mar 6 14:16:18:876 2026 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet4/0/43 changed to up.
%Mar 6 14:16:18:878 2026 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet4/0/43 changed to up.
%Mar 6 14:16:18:901 2026 H3C LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=4; Nearest bridge agent neighbor created on port GigabitEthernet4/0/43 (IfIndex 232), neighbor's chassis ID is e4a8-xxxx-e811, port ID is e4a8-xxxx-e811.
*Mar 6 14:16:19:684 2026 H3C DOT1X/7/PACKET: -Slot=1;
Received a packet on interface GigabitEthernet1/0/38.
Destination Mac Address=0180-c200-0003
Source Mac Address=e4a8-xxxx-e811
Mac Frame Type=888e
Protocol Version ID=1
Packet Type=1
Packet Length=0.
*Mar 6 14:16:19:682 2026 H3C DOT1X/7/PACKET: -Slot=3;
Received a packet on interface GigabitEthernet3/0/37.
Mac Frame Type=888e
Packet Type=1
Packet Length=0.
之后查看mac地址,能看到现象复现:
e4a8-xxxx-e811 235 DOT1X GE3/0/37 N
将4/0/43口shutdown,debug dot1x了一段时间,也没有收到源mac是e4a8-xxxx-e811的eap报文,也没有从其他接口学到此mac地址
3、测试期间,在接口上做匹配源mac地址是e4a8-xxxx-e811的流统,但只有4/0/43口有计数,debug日志中有收到此mac的eap报文的接口,并没有流统到。
4、进一步查看接口配置,发现接口下没有启用dot1x , 接口配上dot1x启用后,恢复正常。
interface GigabitEthernet4/0/26
port link-type hybrid
undo port hybrid vlan 1
port hybrid vlan 36 235 to 236 238 untagged
port hybrid pvid vlan 36
mac-vlan enable
ip verify source ip-address mac-address
undo dot1x handshake
dot1x mandatory-domain lan
undo dot1x multicast-trigger
dot1x re-authenticate
dot1x unicast-trigger
dot1x guest-vlan 235
dot1x auth-fail vlan 236
dot1x critical vlan 238
dhcp snooping binding record
出现问题现象的原因:
当接口downup或下接终端重启,终端触发1x认证,发送eapol start 组播报文(目的地址为组播MAC地址0180-c200-0003)。
当4/0/43口未开启dot1x,接口pvid vlan是36,报文会在这个vlan广播转发。有个别在vlan36下的终端(如3/0/37 1/0/38下的)收的这个报文后,又回弹给了交换机(回弹机制不详,正常应该会丢弃掉会自己认证无关的eap报文,交换机中大部分接口其他终端也没这个现象),导致交换机从这些端口也学到了43口终端的mac地址;
当4/0/43口开启了dot1x,交换机从43口收到这个报文,会上送cpu进行1x认证处理,就不会泛洪到其他终端。
恢复接口dot1x配置。另外可以配置上端口隔离,避免接口误删dot1x配置时再次触发此问题。
