Print
知
某局点 S5560X-EI重启后堆叠分裂无法恢复
2026-04-27 发表
问题描述
现场4台S5560X-EI堆叠,环境异常掉电,重新上电后slot2无法加入堆叠组。
过程分析
1、重新上电后检查配置,发现slot2d的irf-port相关的配置丢失。
2、查看诊断信息,发现slot2的配置文件时间异常,slot1的时间是4/16,slot3和slot4时间是4/13
  ===============dir /all slot 1===============
Directory of flash:
   0 -rw-      220684 Jan 01 2013 08:00:01   defaultfile.zip
   1 drw-           - Jan 01 2013 08:00:35   diagfile
   2 -rw-         735 Jan 01 2013 10:16:33   hostkey
   3 -rw-        6094 Apr 16 2026 20:59:11   ifindex.dat
   4 -rw-           0 Nov 19 2024 16:00:55   lauth.dat
   5 drw-           - Jan 01 2013 08:00:38   license
   6 drw-           - Jan 01 2013 08:25:32   logfile
   7 drw-           - Jan 01 2013 08:00:53   pki
   8 -rw-     5395456 Aug 09 2008 04:00:00   s5560x_ei-cmw710-boot-r1118p07.bin
   9 -rw-     5396480 Jan 01 2013 08:22:03   s5560x_ei-cmw710-boot-r1119p09.bin
  10 -rw-     1052672 Jan 01 2013 08:24:35   s5560x_ei-cmw710-freeradius-r1119p09.bin
  11 -rw-    71542784 Aug 09 2008 04:00:00   s5560x_ei-cmw710-system-r1118p07.bin
  12 -rw-    86925312 Jan 01 2013 08:24:32   s5560x_ei-cmw710-system-r1119p09.bin
  13 drw-           - Jan 01 2013 08:00:35   seclog
  14 -rw-         591 Jan 01 2013 10:16:41   serverkey
  15 -rw-       73728 Apr 24 2026 11:59:12   ssh_141.1.255.15_s5560x-54c-ei_20260424115809.gz
  16 -rw-       70196 Apr 16 2026 20:59:15   startup.cfg
  17 -rw-      602938 Apr 16 2026 20:59:17   startup.mdb
  18 drw-           - Jan 01 2013 08:27:41   versionInfo
  19 -rwh          20 Apr 24 2026 10:25:55   .snmpboots
  20 drwh           - Jan 01 2013 08:25:12   .trash
514048 KB total (243848 KB free)
  ===============dir /all slot 2===============
Directory of slot2#flash:
   0 -rw-      220684 Jan 01 2013 12:55:48   defaultfile.zip
   2 -rw-         735 Apr 24 2026 10:26:18   hostkey
   3 -rw-        1531 Jan 01 2013 12:54:38   ifindex.dat
   4 -rw-           0 Jan 01 2013 08:03:48   lauth.dat
   6 drw-           - Jan 01 2013 08:28:14   logfile
   7 drw-           - Apr 24 2026 10:26:14   pki
   9 -rw-     5396480 Jan 01 2013 08:24:56   s5560x_ei-cmw710-boot-r1119p09.bin
  10 -rw-     1052672 Jan 01 2013 08:27:28   s5560x_ei-cmw710-freeradius-r1119p09.bin
  12 -rw-    86925312 Jan 01 2013 08:27:26   s5560x_ei-cmw710-system-r1119p09.bin
  14 -rw-         591 Apr 24 2026 10:26:21   serverkey
  15 -rw-        4816 Jan 01 2013 12:54:39   startup.cfg
  16 -rw-      109309 Jan 01 2013 12:54:40   startup.mdb
  17 drw-           - Jan 01 2013 08:30:23   versionInfo
  18 -rwh          20 Apr 24 2026 10:25:55   .snmpboots
  19 drwh           - Jan 01 2013 08:27:46   .trash
514048 KB total (254536 KB free)
  ===============dir /all slot 3===============
Directory of slot3#flash:
   2 -rw-         735 Jan 01 2013 08:03:50   hostkey
   3 -rw-        6094 Apr 16 2026 20:59:12   ifindex.dat
   4 -rw-           0 Jan 01 2013 08:03:31   lauth.dat
   6 drw-           - Jan 01 2013 08:27:38   logfile
   7 drw-           - Jan 01 2013 08:04:00   pki
   9 -rw-     5396480 Jan 01 2013 08:24:11   s5560x_ei-cmw710-boot-r1119p09.bin
  10 -rw-     1052672 Jan 01 2013 08:26:43   s5560x_ei-cmw710-freeradius-r1119p09.bin
  12 -rw-    86925312 Jan 01 2013 08:26:40   s5560x_ei-cmw710-system-r1119p09.bin
  14 -rw-         591 Jan 01 2013 08:03:58   serverkey
  15 -rw-       70196 Apr 13 2026 09:45:49   startup.cfg
  16 -rw-      602938 Apr 13 2026 09:46:13   startup.mdb
  17 drw-           - Jan 01 2013 08:29:48   versionInfo
  18 -rwh          20 Apr 24 2026 10:26:00   .snmpboots
  19 drwh           - Jan 01 2013 08:27:26   .trash
514048 KB total (254128 KB free)
  ===============dir /all slot 4===============
Directory of slot4#flash:
   2 -rw-         735 Jan 01 2013 08:03:26   hostkey
   4 -rw-           0 Jan 01 2013 08:03:20   lauth.dat
   6 drw-           - Jan 01 2013 08:15:01   logfile
   7 drw-           - Jan 01 2013 08:03:37   pki
   9 -rw-     5396480 Jan 01 2013 08:11:44   s5560x_ei-cmw710-boot-r1119p09.bin
  10 -rw-     1052672 Jan 01 2013 08:14:16   s5560x_ei-cmw710-freeradius-r1119p09.bin
  12 -rw-    86925312 Jan 01 2013 08:14:14   s5560x_ei-cmw710-system-r1119p09.bin
  14 -rw-         591 Jan 01 2013 08:03:36   serverkey
  16 -rw-      602938 Apr 13 2026 09:46:23   startup.mdb
  17 drw-           - Jan 01 2013 08:17:11   versionInfo
  18 -rwh          20 Apr 24 2026 10:26:03   .snmpboots
  19 drwh           - Jan 01 2013 08:14:44   .trash
514048 KB total (254140 KB free)
3、进一步查看日志信息发现,4/16保存操作时没过多久就ssh登出了
%@4343915%Apr 16 20:59:11:514 2026 NN-USR-AL-F15-SW-IRF SHELL/6/SHELL_CMD_INPUT: Input string for the save command is the Enter key.
%@4343916%Apr 16 20:59:11:609 2026 NN-USR-AL-F15-SW-IRF SHELL/6/SHELL_CMD_CONFIRM: Confirm option of command save is yes.
%@4343917%Apr 16 20:59:18:941 2026 NN-USR-AL-F15-SW-IRF SSHS/6/SSHS_DISCONNECT: SSH user nnadmin (IP: 102.209.1.18) disconnected from the server.
%@4343918%Apr 16 20:59:20:066 2026 NN-USR-AL-F15-SW-IRF SSHS/6/SSHS_LOG: Accepted password for nnadmin from 102.209.1.18 port 57840.
4、分析是触发该已知问题:关于H3C部分产品保存配置时退出登录导致配置丢失的技术公告 - 知了社区
解决方法
堆叠环境保存配置是一台一台执行的,涉及该问题的版本建议保存配置时预留2分钟时间,如果堆叠成员数量越多,需要预留的时间越长。
