Print
知
某局点S6850 super切换用户失败
2026-05-19 发表
问题描述
S6850登陆通过tacas认证。super network-operator切换用户时,输入用户名和密码后又弹出用户名登陆界面。
过程分析
查看交换机侧相关配置,未发现异常
line class vty
 user-role network-operator
line vty 0 63
 authentication-mode scheme
 user-role network-admin
 protocol inbound ssh
 idle-timeout 5 0
 command authorization
 command accounting
 ssh server enable
 super authentication-mode scheme
 super password role network-admin simple testsuperlocal
hwtacacs scheme acs
 primary authentication 18.1.185.202
 primary authorization 18.1.185.202
 primary accounting 18.1.185.202
 key authentication simple test
 key authorization simple test
 key accounting simple test
 timer response-timeout 1
 user-name-format without-domain
 nas-ip 18.1.82.2
 vpn-instance management_vpn
domain cxmt
 authentication default hwtacacs-scheme acs local
 authorization default hwtacacs-scheme acs local
 accounting default hwtacacs-scheme acs local
//authentication super hwtacacs-scheme acs
domain sdn
 domain default enable cxmt
domain system
 state block
查看手册发现切换到的是不是自定义角色,需要配置allowed-roles=”role”的配置(服务器不同,配置的地方不同)。
解决方法
在服务器侧配置allowed-roles=”role”后正常
