Print
知
S6850 聚合状态异常
2026-06-22 发表
问题描述
从日志看19:13:19分端口UP,但是到19:39:26端口才被选中。
%Jun  1 19:13:19:753 2026 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface Twenty-FiveGigE1/0/15 changed to up.
%Jun  1 19:39:26:402 2026 H3C LAGG/6/LAGG_ACTIVE: Member port WGE1/0/15 of aggregation group BAGG15 changed to the active state.
%Jun  1 19:39:26:404 2026 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface Twenty-FiveGigE1/0/15 changed to up.
过程分析
从LACP报文的收发看,19:13:19插入的光模块后1/0/15口UP,但是一直没有收到lacp,到19:39:24才收到第一个lacp报文,19:39:26协商完成。
 [H3C-probe]display system internal link-aggregation lacp packet interface Twenty-FiveGigE 1/0/15
 Aggregate interface: Bridge-Aggregation15
 Data and Time: 06/01 19:39:26.650 ///协商完成
 Packet description:
 Local:  SystemID=65535 SystemMAC=b8ce-f6c2-3fa0 Key=21 Index=1 Priority=255 Flag=63
 Remote: SystemID=32768 SystemMAC=6001-0000-0002 Key=40015 Index=16404 Priority=32768 Flag=61
 Data and Time: 06/01 19:39:26.372
 Packet description:
 Local:  SystemID=65535 SystemMAC=b8ce-f6c2-3fa0 Key=21 Index=1 Priority=255 Flag=15
 Remote: SystemID=32768 SystemMAC=6001-0000-0002 Key=40015 Index=16404 Priority=32768 Flag=13
 Data and Time: 06/01 19:39:24.249 ///此次故障第一次收到LACP报文
 Packet description:
 Local:  SystemID=65535 SystemMAC=b8ce-f6c2-3fa0 Key=21 Index=1 Priority=255 Flag=199
 Remote: SystemID=65535 SystemMAC=0000-0000-0000 Key=1 Index=1 Priority=255 Flag=3
 Data and Time: 10/19 15:50:18.505 //上一次LACP报文有变化
 Packet description:
 Data and Time: 10/19 15:50:18.205
 Packet description:
综上,故障时1/0/15端口收不到LACP报文,导致端口无法选中
解决方法
建议排查下对端是否有异常。后续如有故障,建议故障时采集display link-aggregation verbose,对比查看哪些信息有异常,如mac、优先级、操作key、状态标志等信息。
