Print
知
S12508G-AF用反射端口方式做镜像多出口不成功
2026-06-28 发表
问题描述
S12508G-AF  R7643P06设备使用反射端口方式做镜像多出口,前期怀疑镜像资源不足,即违背了1个芯片最多四个镜像组+方向的逻辑,故进行了调整,减少镜像数量为单向3个,但是测试下来镜像组1和镜像组3依旧不生效,配置检查probe vlan关闭mac地址学习。
过程分析
检查配置如下,1块板卡的镜像资源数不超过4个,资源数足够,并无异常
<hx>display  mirroring-group  all
Mirroring group 1:
    Type: Remote source
    Status: Active
    Mirroring port:
      Ten-GigabitEthernet1/2/0/13  Inbound
      Ten-GigabitEthernet1/2/0/14  Inbound
    Reflector port: Ten-GigabitEthernet1/2/0/12
    Remote probe VLAN: 1601
Mirroring group 2:
    Type: Remote source
    Status: Active
    Mirroring port:
      Ten-GigabitEthernet1/2/0/30  Inbound
      Ten-GigabitEthernet1/2/0/31  Inbound
    Reflector port: Ten-GigabitEthernet1/2/0/29
    Remote probe VLAN: 1602
Mirroring group 3:
    Type: Remote source
    Status: Active
    Mirroring port:
      Ten-GigabitEthernet2/2/0/20  Both
    Reflector port: Ten-GigabitEthernet1/3/0/5
    Remote probe VLAN: 1603
解决方法
现网版本有个问题,远程镜像反射口所在芯片probe vlan底层的mac学习没有正常关闭,在R7645版本解决。
本地可复现:
[hx-probe]dis mirroring-group 1
Mirroring group 1:
    Type: Remote source
    Status: Active
    Mirroring port:
      Ten-GigabitEthernet1/2/0/13  Both
      Ten-GigabitEthernet1/2/0/14  Both
[yhq-qzf-zww-hx-probe]bcm ch 1 sl 2 ch 0 vlan/1601
Current settings:
         VRF=-3
         OuterTPID=0x8100
         LearnDisable=0     这里LearnDisable为1表示关闭mac学习,为0表示打开了mac学习,正常probe vlan要关闭mac学习
         UnknownIp6McastToCpu=0
         UnknownIp4McastToCpu=0
         Ip4Disable=0
         Ip6Disable=0
反射口在probe vlan还会学习mac,影响镜像流量转发:
[yhq-qzf-zww-hx-probe]bcm ch 1 sl 2 ch 0 l2/show/vlan=1601
mac=00:10:94:00:00:63 vlan=1601 GPORT=0x29 modid=0 port=41/xe8 SDHit Group=Learnt
mac=00:00:01:00:00:5f vlan=1601 GPORT=0x29 modid=0 port=41/xe8 SDHit Group=Learnt
mac=00:00:01:00:00:08 vlan=1601 GPORT=0x29 modid=0 port=41/xe8 SDHit Group=Learnt
mac=00:10:94:00:00:5d vlan=1601 GPORT=0x29 modid=0 port=41/xe8 SDHit Group=Learnt
mac=00:10:94:00:00:58 vlan=1601 GPORT=0x29 modid=0 port=41/xe8 SDHit Group=Learnt
mac=00:00:01:00:00:29 vlan=1601 GPORT=0x29 modid=0 port=41/xe8 SDHit Group=Learnt
检查方法:确认probe vlan下有没有正常关闭mac学习,反射口所在芯片查询probe vlan:bcm ch 1 sl 2 ch 0 vlan/1601,确认是否打开了mac学习
恢复方法:反射口所在芯片,找个口放通probe vlan,在probe vlan下打开mac学习再重新关闭mac学习,再将前面口放通的probe vlan去掉。
