Print
浪潮M5服务器安装RHEL6.x操作系统USB接口使用异常
1天前 发表
组网及说明
现场NF5466M5主机安装操作系统RHEL6.7
告警信息
Sep 22 11:02:48 localhost pulseaudio[7275]: pid.c: Stale PID file, overwriting.
Sep 22 11:05:39 localhost kernel: usb 1-2: new low speed USB device number 4 using xhci_hcd
Sep 22 11:05:39 localhost kernel: usb 1-2: device descriptor read/64, error -71
Sep 22 11:05:39 localhost kernel: xhci_hcd 0000:00:14.0: Setup ERROR: setup context command for slot 3.
Sep 22 11:05:39 localhost kernel: hub 1-0:1.0: unable to enumerate USB device on port 2
Sep 22 11:05:41 localhost kernel: dmar: DRHD: handling fault status reg 2
Sep 22 11:05:41 localhost kernel: dmar: DMAR:[DMA Read] Request device [00:14.0] fault addr 0
Sep 22 11:05:41 localhost kernel: DMAR:[fault reason 06] PTE Read access is not set
Sep 22 11:05:47 localhost kernel: xhci_hcd 0000:00:14.0: Timeout while waiting for a slot
Sep 22 11:05:56 localhost kernel: xhci_hcd 0000:00:14.0: Stopped the command ring failed, maybe the host is dead
Sep 22 11:05:56 localhost kernel: xhci_hcd 0000:00:14.0: Abort command ring failed
Sep 22 11:05:56 localhost kernel: xhci_hcd 0000:00:14.0: HC died; cleaning up
Sep 22 11:05:56 localhost kernel: hub 1-0:1.0: cannot reset port 2 (err = -19)
Sep 22 11:05:56 localhost kernel: hub 1-0:1.0: cannot disable port 2 (err = -19)
问题描述
现场NF5466M5主机,安装操作系统RHEL6.7,USB设备无法使用,并且有接入USB设备后宕机的情况。
过程分析
M5/M4机型grub.conf及menu.lst有iommu=on的字样。
解决方法
重启后在菜单选择的时候按e修改参数,将intel_iommu=on amd_iommu=on中的on改成off,进入系统之后再修改grub.conf文件,修改内容与前面一致。
sosreport中看到/proc/cmdline中有intel_iommu=on amd_iommu=on参数。
在低版本内核中,还存在启动intel_iommu后kdump服务无法收集vmcore的问题,这些问题都和RHEL6版本的内核中相关的实现有关。
