Print
知
S7506X-G本地镜像口导致设备分裂重启问题
2026-07-09 发表
问题描述
异常重启记录
[193526]  ===============display version===============
[193526]H3C Comware Software, Version 7.1.070, Release 7754P10
[193526]Copyright (c) 2004-2023 New H3C Technologies Co., Ltd. All rights reserved.
[193526]H3C S7506X-G uptime is 127 weeks, 6 days, 1 hour, 23 minutes
[193526]Last reboot reason : IRF Merge reboot
547] MemberID NewID    IRF-Port1                     IRF-Port2
[193547] 1        1        Ten-GigabitEthernet1/0/0/39   disable
[193547]                   Ten-GigabitEthernet1/0/0/40
[193547] 2        2        disable                       Ten-GigabitEthernet2/0/0/39
[193547]                                                 Ten-GigabitEthernet2/0/0/40
[193547]=========================================================
存在镜像配置:
[103400][GH-HJ-7506X-G-IRF]dis mirroring-group all
[103400]Mirroring group 1:
[103400]    Type: Local
[103400]    Status: Incomplete
[103400]    Mirroring port:
[103400]      GigabitEthernet1/0/0/1  Both
[103400]      GigabitEthernet1/0/0/2  Both
[103400]      GigabitEthernet1/0/0/3  Both
[103400]      GigabitEthernet1/0/0/4  Both
[103401]Mirroring group 2:
[103401]    Type: Local
[103401]    Status: Active
[103401]    Mirroring port:
[103401]      GigabitEthernet2/0/0/1  Both
[103401]      GigabitEthernet2/0/0/2  Both
[103401]      GigabitEthernet2/0/0/3  Both
[103401]      GigabitEthernet2/0/0/4  Both
过程分析
当前版本存在已知问题如下:
·          问题现象:设备配置端口镜像后出现单板重启情况。
·          问题产生条件:镜像源端口在 SD或SC系列接口板上,且单板上镜像流量总带宽大于镜像目的口带宽。
·          说明:无。
解决方法
升级到R7764版本解决
