SQLSERVER 数据库还原备份文件和日志,达到完全恢复。
--还原到备库
--数据库全量恢复
USE [master]
RESTORE DATABASE [QQQ] FROM DISK = N'd:\clustershare\QQQ_FullBackup_2026_10_11_175629.bak' WITH FILE = 1,NOUNLOAD,NORECOVERY, REPLACE, STATS = 5
GO
--还原日志
--注意一定要用NORECOVERY来还原备份
USE [master]
RESTORE DATABASE [QQQ] FROM DISK = N'd:\clustershare\QQQ_logBackup_2026_10_11_175629.bak' WITH FILE = 1, NOUNLOAD,NORECOVERY, REPLACE, STATS = 5
GO
查看还原进度
SELECT percent_complete,start_time,command
FROM sys.dm_exec_requests WHERE command LIKE 'RESTORE%'
