Print
某局点 WA4620i-ACN V7瘦AP切换为V5胖AP经验案例
2018-03-21 发表
现场AP型号WA4620i-ACN本来挂在V7 AC上,先由于客户需求,需要将其切换成胖AP独立工作,但此型号AP只有V5的胖版本。代理商按照正常胖瘦切换的流程不成功。
1、 查看当前AP的版本为V7瘦版本
<H3C>dis version
H3C Comware Software, Version 7.1.064, Release 2219
Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. All rights reserved.
H3C WA4620i-ACN uptime is 0 weeks, 0 days, 0 hours, 1 minute
Last reboot reason : Power on
Boot image: flash:/wa4600-boot.bin
Boot image version: 7.1.064, Release 2219
  Compiled Dec 19 2017 16:00:00
System image: flash:/wa4600-system.bin
System image version: 7.1.064, Release 2219
with 1 APM86791 1000MHz Processor
256M bytes DDR3
32M bytes NorFlash Memory
Hardware Version is Ver.A
CPLD Version is 006
Basic Bootrom Version is 2.04
Extend Bootrom Version is 7.04
[Subslot 0]H3C WA4620i-ACN Hardware Version is Ver.A
[SLOT 1]GE1/0/1     (Hardware)Ver.A, (Driver)1.0
[SLOT 1]GE1/0/2     (Hardware)Ver.A, (Driver)1.0
[SLOT 1]RADIO1/0/1  (Hardware)Ver.A, (Driver)1.0
[SLOT 1]RADIO1/0/2  (Hardware)Ver.A, (Driver)1.0
2、重启设备并格式化之前的版本
<H3C>reboot
Current configuration may be lost after the reboot, save current configuration? [Y/N]:n
Now rebooting, please wait...
%Jan 15 14:45:44:590 2018 H3C DEV/5/SYSTEM_REBOOT: System is rebooting now.
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing............Done!
*                 H3C WA4620i-ACN BootWare, Version 7.04                   *
Compiled Date       : Mar 21 2017
CPU Type            : APM86791
CPU L1 Cache        : 32KB
CPU Clock Speed     : 1000MHz
Memory Type         : DDR3 SDRAM
Memory Size         : 256MB
BootWare Size       : 512KB
Flash Size          : 32MB
CPLD Version        : 006
PCB Version         : Ver.A
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System
|<2> Enter Serial SubMenu
|<3> Enter Ethernet SubMenu
|<4> File Control
|<5> Restore to Factory Default Configuration
|<6> Skip Current System Configuration
|<7> BootWare Operation Menu
|<8> Skip Authentication for Console Login
|<9> Storage Device Operation
|<0> Reboot
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Enter your choice(0-9):
Warning:All files on flash will be lost! Are you sure to format? [Y/N]Y.....
Format success.//格式化成功
3、上传V5胖版本文件,更新bootware
|<1> Boot System
|<4> File Control
|<0> Reboot
|<1> Boot System
|<4> File Control
|<0> Reboot
Enter your choice(0-9): 3
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash
|<1> Download Image Program To SDRAM And Run
|<2> Update Main Image File
|<3> Update Backup Image File
|<4> Download Files(*.*)
|<5> Modify Ethernet Parameter
|<0> Exit To Main Menu
|<Ensure The Parameter Be Modified Before Downloading!>
Enter your choice(0-5): 5
==========================<ETHERNET PARAMETER SET>==========================
|Note:       &#39;.&#39; = Clear field.
|            &#39;-&#39; = Go to previous field.
|         Ctrl+D = Quit.
Protocol (FTP or TFTP) :tftp ftp
Load File Name         :wa4600_fat.bin
                       :wa4600_fat.bin
Target File Name       :wa4600_fat.bin
                       :wa4600_fat.bin
Server IP Address      :192.168.0.1 2.2.2.2
Local IP Address       :192.168.0.2 2.2.2.1
Subnet Mask            :0.0.0.0
Gateway IP Address     :0.0.0.0
FTP User Name          :123
FTP User Password      :****** ***
Enter your choice(0-5): 1
Loading.....................................................................
..................Done.
12189696 bytes downloaded!
The image is self-decompressing.............................................
...................................................................Done.
Extended BootWare Version is not equal,updating? [Y/N] Y
Updating Extended BootWare..........Done.//升级bootware成功
BootWare updated,System is rebooting now.
The Extend BootWare is self-decompressing..........Done!//bootware启动成功
4、再次上传版本并更新启动版本文件
*                 H3C WA4620i-ACN BootWare, Version 2.05                   *
Copyright (c) 2004-2016 Hangzhou H3C Technologies Co., Ltd.
Compiled Date       : Jun 12 2016
CPU Type            : APM86791
CPU L1 Cache        : 32KB
Memory Type         : SDRAM
Memory Size         : 256MB
Flash Size          : 32MB
CPLD Version        : 006
PCB Version         : Ver.A
Read net params from bootrom failed, use the default value
Press Ctrl+B to enter extended boot menu...
BootWare password: Not required. Please press Enter to continue.
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System
|<4> File Control
|<8> Clear Super Password
|<0> Reboot
Format success.//再次格式化
|<1> Boot System
|<4> File Control
|<0> Reboot
|<1> Boot System
|<4> File Control
|<0> Reboot
|<1> Download Application Program To SDRAM And Run
|<2> Update Main Application File
|<3> Modify Ethernet Parameter
Enter your choice(0-3): 3
|Note:       &#39;.&#39; = Clear field.                                            |
|            &#39;-&#39; = Go to previous field.                                   |
|          Ctrl+D = Quit.                                                  |
Protocol (FTP or TFTP) :ftp ftp
                       :wa4600_fat.bin
Server IP Address      :2.2.2.2
Local IP Address       :2.2.2.1
FTP User Name          :123
FTP User Password      :123
Enter your choice(0-3): 2
..................Done!
Updating File flash:/wa4600_fat.bin.........................................
.......................................................................Done!//重新下载和更新版本
5、完成所有更新后,重启设备
Enter your choice(0-3): 0
|<1> Boot System
|<4> File Control
|<0> Reboot
Enter your choice(0-9): 0
CPU Type            : APM86791
CPU L1 Cache        : 32KB
Memory Type         : SDRAM
Memory Size         : 256MB
Flash Size          : 32MB
CPLD Version        : 006
PCB Version         : Ver.A
Starting to get the main application file--flash:/wa4600_fat.bin!...........
The main application file is self-decompressing.............................
.......Done!
System application is starting...
Startup configuration file does not exist.
User interface con0 is available.
Press ENTER to get started.
<WA4620i-ACN>
#Jan  1 00:00:18:046 2009 WA4620i-ACN SHELL/4/LOGIN:
 Trap 1.3.6.1.4.1.25506.2.2.1.1.3.0.1<hh3cLogIn>: login from Console
%Jan  1 00:00:18:047 2009 WA4620i-ACN SHELL/5/SHELL_LOGIN: Console logged in from con0.
6、查看版本文件,切换成功。
<WA4620i-ACN>dis version
H3C Comware Platform Software
Comware Software, Version 5.20, Release 1508P03
Copyright (c) 2004-2016 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C WA4620i-ACN uptime is 0 week, 0 day, 0 hour, 0 minute
 CPU type: APM86791
 256M bytes DDR3 SDRAM Memory
 32M bytes Flash Memory
 Pcb             Version:  Ver.A
 CPLD            Version:  006
 Basic  BootROM  Version:  2.04
 Extend BootROM  Version:  2.05
 [SLOT  1]CON           (Hardware)Ver.A,        (Driver)1.0,    (Cpld)6.0
 [SLOT  1]GE1/0/1       (Hardware)Ver.A,        (Driver)1.0,    (Cpld)6.0
 [SLOT  1]GE1/0/2       (Hardware)Ver.A,        (Driver)1.0,    (Cpld)6.0
 [SLOT  1]RADIO1/0/1    (Hardware)Ver.A,        (Driver)1.0,    (Cpld)6.0
 [SLOT  1]RADIO1/0/2    (Hardware)Ver.B,        (Driver)1.0,    (Cpld)6.0
1、在AP胖瘦切换之前,要先确认AP是否支持胖版本;
2、V7的瘦AP切换为V5的胖AP需要上传两次软件版本,第一次更新bootware,第二次更新AP的启动版本文件;
3、在加载版本文件的过程中,有可能出现提示失败的情况,这时候可以更换地址,ftp/tftp方式尝试;
