客户现场使用两台M9010配置IRF2堆叠,在堆叠完成后发现日志中chassis 2中的所有板卡均在不停的从Normal和Fault之间来回切换。通过“display device verbose”查询到目前设备侧两块主控和两块四代防火墙插卡均无法识别。
1、在堆叠未成功情况下从主设备上将logfile文件下载下来,在设备保存的日志中发现,其实业务板卡和主控板卡是可以被识别的。
%@767%Mar 20 21:30:46:859 2018 H3C DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on chassis 2 slot 3, type is NSQM1FWDFG0.
%@768%Mar 20 21:30:46:909 2018 H3C DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on chassis 2 slot 2, type is NSQM1FWDFG0.
2、从收集堆叠分裂后主设备保存的配置文件中可见一斑,在保存的配置文件中配置是正常的(IRF堆叠是能正常建立的)。
===============display saved-cOnfiguration===============
version 7.1.064, Release 9121P24
sysname SXXX-2#IDC-B003-L05&06-BFQ-FW01&02-H3CM9010
。。。。。。(此处省略无关配置)
irf-port 1/2
port group interface FortyGigE1/6/0/35 mode enhanced
port group interface FortyGigE1/6/0/36 mode enhanced
port group interface FortyGigE1/7/0/36 mode enhanced
irf-port 2/1
port group interface FortyGigE2/6/0/35 mode enhanced
port group interface FortyGigE2/6/0/36 mode enhanced
port group interface FortyGigE2/7/0/35 mode enhanced
port group interface FortyGigE2/7/0/36 mode enhanced
3、接着再去查日志,发现一个很有趣的问题,在端口2/7/0/35端口不能收到IRF包后,其他IRF端口也跟着DOWN掉了。所以出现了之前现场出现的日志中板卡从Normal和Fault之间不停的切换。原因就在这里!
%@747%Mar 20 21:27:15:210 2018 H3C DRVPLAT/4/DrvDebug: -Chassis=2-Slot=7;
The port Forty2/7/0/35 can't receive irf pkt and has been changed to inactive status, please check.
%@748%Mar 20 21:27:17:544 2018 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface FortyGigE1/7/0/35 changed to down.
%@749%Mar 20 21:27:17:545 2018 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface FortyGigE1/7/0/35 changed to down.
%@750%Mar 20 21:27:23:565 2018 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface FortyGigE1/7/0/36 changed to down.
%@751%Mar 20 21:27:23:565 2018 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface FortyGigE1/7/0/36 changed to down.
4、既然原因已经明了了,那么就来看到底Forty2/7/0/35为什么会出现不能接受IRF协商包?
而在配置中看到:
A堆叠设备:
irf-port 1/2
B堆叠设备:
irf-port 2/1
日志中报错的端口正好是在A设备中没有配置的端口,所以由此判断在堆叠配置中IRF PORT中的端口必须对应。也就是主框和备框之间接口数量、端口编号必须一致。
1、删除B设备中“port group interface FortyGigE2/7/0/35 mode enhanced
”命令。
irf-port 2/1
2、在A设备中添加“port group interface FortyGigE1/7/0/35 mode enhanced
”命令。
irf-port 1/2
不仅是M9000设备在堆叠的时候注意堆叠端口数量和类型需要对应,在其他网络设备做堆叠中也需要注意此问题。
