不涉及
某局点目前的控制器型号是WX3510H,版本是 Version 7.1.064, Customer 5205P02
新添加一WA2620X的AP,做完配置之后AP注册不上,能正常获取到地址,AP的状态目前均为I。
AP name APID State Model Serial ID
mct-79-1280 34 I WA2620X 219801A0KTM171001505
d461-feef-aca0-8hao1-85 10 R/M WA4320X 219801A0REM171000052
d461-feef-b0c0-6hao1-80 18 R/M WA4320X 219801A0REM171000170
d461-feef-b140-6hao3-82 20 R/M WA4320X 219801A0REM171000172
分别在AC和telnet到AP上面开启debugging wlan capwap all ,输出信息如下:
在AC上:
*Jun 27 18:33:10:696 2018 WAC-Master-DOWN CWS/7/RCV_PKT: Received discovery request from AP: IP address=172.23.0.151, MAC address=ac74-09a9-1280, serial ID=219801A0KTM171001505, AP name=mct-79-1280, model=WA2620X, last IP=172.23.0.151.
*Jun 27 18:33:10:698 2018 WAC-Master-DOWN CWS/7/EVENT: Filling AC Descriptor TLV. LicenseType[1] MaxSupportNum[256] JoinCount[21]. //收到AP发送过来的discover request报文
*Jun 27 18:33:10:699 2018 WAC-Master-DOWN CWS/7/SND_PKT: Sent discovery response with SeqNum 0 to AP at 172.23.0.151:64340.
*Jun 27 18:33:10:699 2018 WAC-Master-DOWN CWS/7/SND_PKT: Sent discovery response to AP at 172.23.0.151:64340, Length=128.
*Jun 27 18:33:15:720 2018 WAC-Master-DOWN CWS/7/ERROR: Failed to match image data request with SeqNum 2 from AP at 172.23.0.151:6434 //未能匹配图片数据请求,意思找不到可以匹配的AP镜像文件
在AP上:
*Jan 1 00:04:28:926 2014 H3C CWC/7/TMR: Retransmission Timer of TunnelId:1 expired.
*Jan 1 00:04:28:927 2014 H3C CWC/7/ERROR: Failed to retransmit image data request and tore down the tunnel: Number of retransmissions exceeded the limit 3. //重发送AP镜像文件请求失败
*Jan 1 00:04:28:927 2014 H3C CWC/7/FSM: [Tunnel ID: 1] Image Data -> Idle
*Jan 1 00:04:28:927 2014 H3C CWC/7/EVENT: CAPWAP tunnel to AC 172.23.0.66 went down. Reason: Retransmission failed.
*Jan 1 00:04:28:928 2014 H3C CWC/7/FSM: Enter Idle state.
*Jan 1 00:04:28:929 2014 H3C CWC/7/FSM: Enter Discovery state.
仔细检查配置,发现如下配置:
wlan image-load filepath local
wlan apdb WA4320X Ver.A R22510
wlan apdb WA4320X Ver.B R22510
wlan apdb WA4320X Ver.C R22510
wlan apdb WA4320X Ver.D R22510
wlan apdb WA4320X Ver.E R22510
wlan apdb WA4320X Ver.F R22510
查阅命令手册,仅当期望AP使用的软件版本与APDB中存储的该AP型号对应的软件版本不一致时才需要配置本命令。本命令通常用于向AP下发临时版本,建议用户不要自行配置,以免导致AP无法与AC建立CAPWAP隧道。
和现场了解情况为何有如上配置,现场反馈当时是我司一线工程师开局的,意图是让当时的AP下发特定的版本;因此指导现场工程师Telnet到AP上查看WA2620X使用的软硬件版本
[mct-79-1280]dis version
H3C Comware Software, Version 7.1.064, alpha 2104sp17
Hardware Version is Ver.C
于是在AC上增加如下配置,
wlan apdb WA2620X Ver.C A2104sp17
新增AP WA2620X正常上线成功。
