Print
S5130EI EAA实现主备链路自动切换功能说明
2018-08-10 发表
问题描述
客户需要实现如下需求,咨询设备能否支持:
解决方法
经确认,可通过EAA功能实现,配置脚本如下:
nqa entry admin test
 type icmp-echo
  destination ip 192.168.1.100
  frequency 1000
  history-record enable
  history-record number 10
  probe count 5
  probe timeout 500
  reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trap-only              //配置icmp-echo类型NQA检测,ping不通时发送snmp trap
 nqa schedule admin test start-time now lifetime forever
snmp-agent
 snmp-agent community write private
 snmp-agent community read public
 snmp-agent sys-info version all
 snmp-agent target-host trap address udp-domain 192.168.1.1 params securityname public              //指定trap发送主机
 snmp-agent trap enable
rtm environment backup 0             //设置环境变量
rtm cli-policy 1
 event snmp oid 1.3.6.1.4.1.25506.8.3.1.13.1.11.5.97.100.109.105.110.4.116.101.115.116.1 monitor-obj get start-op eq start-val 2 restart-op eq restart-val 3 interval 5
//1.3.6.1.4.1.25506.8.3.1.13.1.11.5.97.100.109.105.110.4.116.101.115.116.1,即为hh3cNqaReactCurrentStatus.5.97.100.109.105.110.4.116.101.115.116.1,表示监控hh3cNqaReactCurrentStatus这一OID,后半部分序列代表NQA名称“admin test
// start-op eq start-val 2 表示触发条件为该节点值为2overThreshold
// restart-op eq restart-val 3 表示再次开启触发开关条件为,该节点值为3belowThreshold
 action 0 cli tclsh
 action 1 cli system-view
 action 2 cli if { $backup==0 } { rtm environment backup 1; int g 1/0/1; shutdown; int g 1/0/2; undo shutdown } else  { rtm environment backup 0; int g 1/0/1; undo shutdown; int g 1/0/2; shutdown }     //通过判断环境变量值,切换1/0/11/0/2端口状态
 user-role network-operator
 user-role network-admin
