型号:F100-C-G
版本:version 5.20, Release 5142P02
需求:L2TP登录后获取权限不同及访问内网资源不同
用户L2TP连接后访问到内网资源不同
1、通过在ppp用户中下发acl控制测试不能限制住
2、测试通过用户拨号时带上不同认证域后获取特定IP,利用安全策略实现对资源的访问控制
domain default enable system
domain test authentication ppp local
authorization ppp none
accounting ppp none
access-limit disable
state active
idle-cut disable
self-service-url disable
ip pool 2 172.16.1.2 172.16.1.100
domain system
accounting ppp none
state active
idle-cut disable
ip pool 1 172.16.1.200
l2tp-group 1
undo tunnel authentication
allow l2tp virtual-template 0
interface Virtual-Template0
ppp authentication-mode chap
ppp ipcp dns 192.168.0.250
remote address pool 2
ip address 172.16.1.1 255.255.255.0
zone name test id 20
priority 10 import
object network range fuwuqi
range 192.168.0.252 192.168.0.252
object network range putong
range 172.16.1.2 172.16.1.100
object network range test
range 172.16.1.200 172.16.1.200
interzone source test destination Trust
rule 0 permit source-ip test destination-ip fuwuqi
service any_service
rule enable
rule 1 permit source-ip putong destination-ip any_address
service any_service
rule enable
注意:用户登录后不带域则进入默认system域获取固定172.16.1.200,此时只能访问服务器192.168.0.252;若用户登录@test可以访问所有资源。
