Print
MSR5620 双出口配置IPSec vpn失败经验案例
2018-09-25发表
组网及说明
问题描述
两台MSR5620作为出口设备,分别连接两根外网线,通过公网建立IPSec vpn。相关配置完成后,感兴趣流地址互ping不通。两台设备的display ike sa显示都为unknownike阶段都没有建立起来:
RT1
< RT1>display ike sa
Connection-ID   Remote      Flag        DOI
   117    180.X.X.166    Unknown     IPsec
RT2
< RT2>display ike sa
   925    140.X.X.195    Unknown     IPsec
过程分析
1、两台设备公网地址互通的前提下,检查两端配置:
RT1
interface LoopBack70
 ip address 10.70.0.1 255.255.255.0
interface GigabitEthernet2/0/2
 ip address 140.X.X.195 255.255.255.0
 nat outbound 3001
 ipsec apply policy sq
ip route-static 10.60.0.1 32 140.X.X.192
acl advanced 3001
 rule 12 deny ip source 10.70.0.1 0 destination 10.60.0.1 0
 rule 100 permit ip
acl advanced 3012
 rule 55 permit ip source 10.70.0.1 0 destination 10.60.0.1 0
ipsec transform-set 1
 esp encryption-algorithm 3des-cbc
 esp authentication-algorithm md5
ipsec policy sq 1 isakmp
 transform-set 1
 security acl 3012
 local-address 140.X.X.195
 remote-address 180.X.X.166
 ike-profile sq
 ike identity fqdn dx
ike profile sq
 keychain sq
 local-identity address 140.X.X.195
 match remote identity address 180.X.X.166 255.255.255.255
 proposal 1
ike proposal 1
 dh group2
ike keychain sq
 pre-shared-key address 180.X.X.166 255.255.255.255 key cipher $c$3$3M1ZR4VWG/7x81MQa+anzqKNObKUP1r8CVTx8=
RT2
RT2配置除了相关地址与RT1不同,其他相关参数均一致。
2、核对两端IPSec vpn的配置无误,此时在RT2上开启debugging ike sa以及debugging ipsec sa,相关报错如下:
*Sep 10 16:47:09:053 2018 RT2 IKE/7/EVENT: Phase1 process started.
*Sep 10 16:47:09:054 2018 RT2 IKE/7/PACKET: vrf = 0, local = 180.X.X.166, remote = 140.X.X.195/500
Collision of phase 1 negotiation is found.
RT2收到了来自RT1IKE报文,在IKE协商过程中提示了冲突。在设备上开启debugging ip packet查看数据包交互情况:
*Sep 10 16:47:22:721 2018 RT2 IPFW/7/IPFW_PACKET:
Receiving, interface = GigabitEthernet2/0/1, version = 4, headlen = 20, tos = 252,
pktlen = 204, pktid = 65, offset = 0, ttl = 254, protocol =17
checksum = 50690, s = 140.X.X.195, d = 180.X.X.166
prompt: Receiving IP packet.
* Sep 10 16:47:22:721 2018 RT2 IPFW/7/IPFW_PACKET:
Sending, interface = GigabitEthernet2/0/3, version = 4, headlen= 20, tos = 252,
pktlen = 144, pktid = 60, offset = 0, ttl = 255, protocol =17
checksum = 50499, s = 180.X.X.166, d = 140.X.X.195
prompt: Sending the packet from local at GigabitEthernet2/0/3
可以看出数据包从GigabitEthernet2/0/1接收,结果从GigabitEthernet2/0/3发出。在RT2上查看路由发现:
ip route-static 0.0.0.0 0 210.X.X.17
ip route-static 0.0.0.0 0 180.X.X.165 preference 70
从这里可以发现问题所在,当10.70.0.1ping 10.60.0.1时,感兴趣流在RT1GigabitEthernet2/0/2口进行IPSec封装后通过公网到达RT2GigabitEthernet2/0/1
RT2在回应报文的时候,由于RT2配置出接口为GigabitEthernet2/0/1的默认路由优先级比出接口为GigabitEthernet2/0/3的优先级低,数据包优先从GigabitEthernet2/0/3发出,路径不一致导致协商冲突。
RT2上配置去往140.X.X.195的明细路由,下一跳指向180.X.X.165,此时ike saipsec sa可以正常建立。
display ike sa
 116     180.X.X.166     RD      IPsec
Flags:
RD--READY RL--REPLACED FD-FADING RK-REKEY
display ipsec sa
  IPsec policy: sq
  Sequence number: 1
  Mode: ISAKMP
    Tunnel id: 0
    Encapsulation mode: tunnel
    Perfect Forward Secrecy:
    Inside VPN:
    Extended Sequence Numbers enable: N
    Traffic Flow Confidentiality enable: N
    Path MTU: 1444
    Tunnel:
        local address: 140.X.X.195
        remote address: 180.X.X.166
    Flow:
        sour addr: 10.70.0.1/255.255.255.255  port: 0  protocol: ip
        dest addr: 10.60.0.1/255.255.255.255  port: 0  protocol: ip
    [Inbound ESP SAs]
      SPI: 1628414150 (0x610fa0c6)
      Connection ID: 545460846593
      Transform set: ESP-ENCRYPT-3DES-CBC ESP-AUTH-MD5
      SA duration (kilobytes/sec): 1843200/3600
      SA remaining duration (kilobytes/sec): 1843199/3299
      Max received sequence-number: 4
      Anti-replay check enable: Y
      Anti-replay window size: 64
      UDP encapsulation used for NAT traversal: N
      Status: Active
    [Outbound ESP SAs]
      SPI: 2623005100 (0x9c57e1ac)
      Connection ID: 708669603842
      Max sent sequence-number: 4
      Status: Active
解决方法
在两台路由器上配置去往对端公网地址的明细路由,保证感兴趣流到达对端设备后从一个端口接收,并且从该端口发出。
< RT1>ip route-static 180.X.X.166 24 140.X.X.192
< RT2>ip route-static 140.X.X.195 24 180.X.X.165
在双出口的组网下,不仅仅需要配置去往对端感兴趣流的明细路由,还需要注意公网之间互通的路由选择,确保感兴趣流到达对端设备后从一个接口接收,回应报文时也从该接口发出。
