Print
WAP系列/WA系列胖AP Console口密码忘记处理方法
2018-11-24 发表
组网及说明
配置步骤
 不需要之前的配置文件,恢复出厂设置
以下标黑部分为设备自动打印部分,标红加粗的命令是需要手动输入。
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing.......................Done!
BootWare Validating...
Press Ctrl+B to enter extended boot menu...  //
如果看到该提示及时按Ctrl+B进入botroom菜单
BotWare password: Not required. Please press Enter to Continue.
Password recovery capability is enabled.  //如果看到此提示,则表示设备开启了密码恢复功能。
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Clear Super Password                                                  |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTEND-ASSISTANT MENU
Ctrl+F: Format File System
Enter your choice(0-9): 6  //选择6 跳过配置文件
Flag Set Success.
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 0  //选择0重启设备
Press ENTER to get started.
跳过启动文件后直接保存当前配置,再重启
save
The current Configuration will be written to the device. Are you sure? [Y/N]:y
(To leave the existing filename unchanged, press the enter key):(输入回车)
Configuration is saved to device successfully.
reboot
Start to check Configuration with next startup Configuration file, please wait.........DONE!
Current Configuration may be lost after the reboot, save current Configuration? [Y/N]:y
重启完成后使用默认配置启动,恢复出厂成功
1.2  保留原有配置,只修改密码
本手册适用于如下产品:WAC360WAC 361、胖APWAP712CWAP722EWAP722SWAP722WAP621
以忽略系统当前配置的方式启动
详细配置过程:
Press Ctrl+B to enter extended boot menu...//
Ctrl+B进入botroom菜单
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Flag Set Success.
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
dir  //查看设备配置文件:startup.cfg
Directory of flash:/
   2     -rw-      1666  Apr 26 2000 12:05:39   startup.cfg
29106 KB total (16876 KB free)
给设备和电脑配置成同网段Ip地址,举例:WAC配置成192.168.100.1/24,电脑配置成192.168.100.2/24),在电脑上使用3CDaemon软件搭建TFTP服务器,打开3CDaemon服务器,目录指向电脑E盘,然后点击应用。
system
 [H3C]interface Vlan-interface 1
[H3C-Vlan-interface1]ip address 192.168.100.1 24
[H3C-Vlan-interface1]quit
[H3C]ping 192.168.100.2
  PING 192.168.100.2: 56  data bytes, press CTRL_C to break
    Reply from 192.168.100.2: bytes=56 Sequence=1 ttl=128 time=7 ms
 //提示设备到电脑网络可达
tftp 192.168.100.2 put startup.cfg
//从设备上下载startup.cfg文件到电脑E
  File will be transferred in binary mode
  Sending file to remote TFTP server. Please wait... |
  TFTP:     1666 bytes sent in 0 seCond(s).
  File uploaded successfully.
下载成功:
可以到本地相关路径(此例子中是E盘)查看到相关文件。
解决方法:
使用记事本打开startup.cfg文件
aux0
覆盖当前配置文件
tftp 192.168.100.20 get startup.cfg
The file startup.cfg exists. Overwrite it? [Y/N]:y
  Verifying server file...
  Deleting the old file, please wait...
  Downloading file from remote TFTP server, please wait....
  TFTP:     1166 bytes received in 0 seCond(s)
  File downloaded successfully.
reboot
Current Configuration may be lost after the reboot, save current Configuration? [Y/N]:n 不保存配置
This command will reboot the device. Continue? [Y/N]:y 确定继续重启
配置关键点
