Print
知
S7000/S7500E/10500系列(V7)交换机启动过程Console信息显示说明
2018-11-26 发表
组网及说明
1 配置需求和说明
把设备的Console线给接上,然后给设备上电,查看设备启动过程显示的信息。
2 组网图
无
配置步骤
3启动过程信息
*                  H3C S5500V2-24P-WiNet BOOTROM, Version 147                  *
Copyright (c) 2004-2017 New H3C Technologies Co., Ltd.
Creation Date       : Apr  5 2017, 12:55:45
CPU Clock Speed     : 1000MHz
Memory Size         : 1024MB
Flash Size          : 512MB
CPLD Version        : 002
PCB Version         : Ver.B
Mac Address         : 60da836e2751
Press Ctrl+B to access EXTENDED BOOT MENU...0
Loading the main image files...
Loading file flash:/s5500v2winet-cmw710-system-r3208p03.bin.....................
........................................Done.
Loading file flash:/s5500v2winet-cmw710-boot-r3208p03.bin........Done.
Image file flash:/s5500v2winet-cmw710-boot-r3208p03.bin is self-decompressing...
............................................................Done.
System is starting...
            Board checking......................LSP7LTSUA!
            SDRAM fast selftest........................OK!
            Flash fast selftest........................OK!
            CPLD selftest..............................OK!
            Switch chip selftest.......................OK!
            PHY selftest...............................OK!
            Please check leds....................FINISHED!
Cryptographic algorithms tests passed.
Startup configuration file does not exist.
Performing automatic configuration... Press CTRL_C or CTRL_D to break.
Automatic configuration attempt: 1.
Not ready for automatic configuration: no interface available.
Waiting for the next...
Automatic configuration is aborted.
Line aux0 is available.
Press ENTER to get started.
%Jan  1 00:00:44:928 2013 H3C SHELL/5/SHELL_LOGIN: TTY logged in from aux0.
说明:%Jan  1 00:00:44:928 2013 H3C SHELL/5/SHELL_LOGIN: TTY logged in from aux0. 这条日志表示console有用户登录。
配置关键点
