Print
知
S7000/S7500E/10500系列(V5)交换机启动过程Console信息显示说明
2018-11-26 发表
组网及说明
1 配置需求和说明
把设备的Console线给接上,然后给设备上电,查看设备启动过程显示的信息。本案例以S3600V2-28TP-EI举例。
2 组网图
无
配置步骤
3启动过程信息
Starting......
Press Ctrl+D to access BASIC BOOT MENU
    *              H3C S3600V2-28TP-EI BOOTROM, Version 133                *
    Copyright (c) 2004-2017 New H3C Technologies Co., Ltd.
    Creation Date       : Apr  5 2017, 13:49:31
    CPU Clock Speed     : 600MHz
    Memory Size         : 256MB
    Flash Size          : 128MB
    CPLD Version        : 001
    PCB Version         : Ver.A
    Mac Address         : 586ab1710285
Press Ctrl-B to enter Extended Boot menu...0
Starting to get the main application file--flash:/S3600V2_E-CMW520-R2112.bin!..
The main application file is self-decompressing................................
...........................Done!
System is starting...
Startup configuration file does not exist.
It will take a long time to get configuration file, please wait...
Press CTRL_C to break
Retrieving configuration file failed!
User interface aux1 is available.
Press ENTER to get started.
<H3C>
#Jan  1 00:05:26:401 2010 H3C SHELL/4/LOGIN:
 Trap 1.3.6.1.4.1.2011.10.2.2.1.1.3.0.1<h3cLogIn>: login from Console
%Jan  1 00:05:26:542 2010 H3C SHELL/5/SHELL_LOGIN: Console logged in from aux1.
<H3C>
<H3C>
说明:如下三行日志是提示有用户从Console登录。
配置关键点
