Print
某局点S12508-AC日志告警资源不足“No enough resource!”经验案例
2018-12-12 发表
组网及说明
无。
问题描述
客户现场反馈交换机大量的日志提示资源不足的报错,但是没有看到macaclroute等规格超标,报错信息如下:
%Nov  5 10:53:07:856 2018 12508-C DRVL3/3/DRVL3_LOG_ERR: -Slot=3; No enough resource!
%Nov  5 10:53:07:973 2018 12508-C DRVL3/3/DRVL3_LOG_ERR: -Slot=4; No enough resource!
%Nov  5 10:53:07:974 2018 12508-C DRVL3/3/DRVL3_LOG_ERR: -Slot=4; No enough resource!
%Nov  5 10:53:07:974 2018 12508-C DRVL3/3/DRVL3_LOG_ERR: -Slot=7; No enough resource!
%Nov  5 10:53:07:977 2018 12508-C DRVL3/3/DRVL3_LOG_ERR: -Slot=3; No enough resource!
过程分析
1、 查看设备的macroute表项:
  ===============display ip routing-table===============
Routing Tables: Public
    Destinations : 30  Routes : 34
Destination/Mask    Proto  Pre  Cost         NextHop         Interface
===============display  mac-address===============
MAC ADDR        VLAN ID   STATE            PORT INDEX              AGING TIME(s)
3ce5-a67c-2d41    10      Learned          Bridge-Aggregation3          AGING
3ce5-a67d-1100    10      Learned          Bridge-Aggregation2          AGING
3ce5-a67d-1300    10      Learned          Bridge-Aggregation2          AGING
3ce5-a67d-4391    10      Learned          Bridge-Aggregation2          AGING
3ce5-a687-67c5    10      Learned          Bridge-Aggregation2          AGING
5866-badb-ca29    10      Learned          Ten-GigabitEthernet7/0/1     AGING
3ce5-a67c-3252    11      Learned          Bridge-Aggregation4          AGING
3ce5-a67d-1100    11      Learned          Bridge-Aggregation2          AGING
3ce5-a67d-1300    11      Learned          Bridge-Aggregation2          AGING
3ce5-a67c-2f29    12      Learned          Bridge-Aggregation2          AGING
3ce5-a67d-1100    12      Learned          Bridge-Aggregation2          AGING
3ce5-a67d-1300    12      Learned          Bridge-Aggregation2          AGING
3ce5-a687-67d3    12      Learned          Bridge-Aggregation2          AGING
c4ca-d9c3-2b82    12      Learned          Bridge-Aggregation2          AGING
5866-badb-ca29    21      Learned          Ten-GigabitEthernet7/0/1     AGING
5866-badb-ca29    66      Learned          Ten-GigabitEthernet7/0/1     AGING
5866-badb-ca29    77      Learned          Ten-GigabitEthernet7/0/1     AGING
5866-badb-ca29    99      Learned          Ten-GigabitEthernet7/0/1     AGING
5866-badb-ca29   101      Learned          Ten-GigabitEthernet7/0/1     AGING
5866-badb-ca29   201      Learned          Ten-GigabitEthernet7/0/1     AGING
5866-badb-ca29   301      Learned          Ten-GigabitEthernet7/0/1     AGING
5866-badb-ca29   401      Learned          Ten-GigabitEthernet7/0/1     AGING
5866-badb-ca29   701      Learned          Ten-GigabitEthernet7/0/1     AGING
5866-badb-ca29   801      Learned          Ten-GigabitEthernet7/0/1     AGING
5866-badb-ca29   901      Learned          Ten-GigabitEthernet7/0/1     AGING
5866-badb-ca29   902      Learned          Ten-GigabitEthernet7/0/1     AGING
5866-badb-ca29   903      Learned          Ten-GigabitEthernet7/0/1     AGING
5866-badb-ca29   904      Learned          Ten-GigabitEthernet7/0/1     AGING
38ad-be79-9001  4002      Learned          Bridge-Aggregation5          AGING
5866-badb-ca29  4002      Learned          Ten-GigabitEthernet7/0/1     AGING
  ---  30 mac address(es) found  ---
2、搜集display qos-acl resource资源也是使用率为0,说明也不是acl资源导致的。
3、但是从诊断里面看出设备组播表项不多了,并且三层转发资源也是不足:
  ===============Display l3mc keyinfo slot 3===============
Resource Info:
TCAM Resource: total 511 free 511
Local DIT Resource: total 780 free 6 usage list:
  L3MC: 774
  ===============Display l3mc keyinfo slot 4===============
Resource Info:
  ===============Display l3mc keyinfo slot 7===============
Resource Info:
通过display device verbose看到现场使用的接口单板为LST1XP8LEB1的EB类单板。 查询官网资料显示EB单板不能修改系统工作模式,因此资源不足建议用户切换部分流量到其他设备上去转发。
解决方法
从诊断里面看出设备组播表项不多了,并且三层转发资源也是不足 。现场使用的接口单板为LST1XP8LEB1的EB类单板, 查询官网资料显示EB单板不能修改系统工作模式,因此资源不足建议用户切换部分流量到其他设备上去转发之后解决资源不足的告警问题。
