Print
某局点MSR810-LM路由器4G拨号失败经验案例
2018-12-12发表
组网及说明
无。
问题描述
某局点MSR810-LM路由器4G拨号失败,现场将4G移动卡换到其他设备可以拨号成功,其他设备正常的SIM卡换到这台设备也是依然拨号失败。和现场客户确认了设备配置的APN接入点以及认证都和其他正常设备是一样的。接下来进行分析。
过程分析
1、搜集配置检查发现没有问题:
dialer-group 1 rule ip permit
controller Cellular1/0
 eth-channel 0
interface Eth-channel1/0:0
 dialer circular enable
 dialer-group 1
 dialer timer idle 0
 dialer timer autodial 5
 dialer number *99# autodial
 ip address cellular-alloc
 ip route-static 0.0.0.0 0 Eth-channel1/0:0
2、搜集4G拨号接口的详细信息分析:
<h3c>display Cellular1/0
Cellular1/0:
 Modem State:
  Hardware Information:
    Model: U8300C
    Manufacturer: LONGSUNG
    Modem Firmware Version: QA30002.1.4_MV11(4534_1.1.7_L1113)
    International Mobile Equipment Identity (IMEI): 862104022057522
    International Mobile Subscriber Identity (IMSI): 460026265049226
    Hardware Version: 30000
    Modem Status: Online
  Profile Information:
    Profile index: 1
      PDP Type: IPv4v6
      Header Compression: Off
      Data Compression: Off
      Access Point Name (APN): XXXXX  //APN接入点确认没有问题。
      Authentication: CHAP
      Username: XXXXXX   //认证的用户名也是没有问题。
  * - Default profile
  Network Information:
    Current Service Status: No Service  //没有服务,网络没有注册上去
    Registration Status: Not Registered
    Current Roaming Status: Unknown
    Current Data Bearer Technology: Unknown
    Network Selection Mode: Automatic
    Current IP address Mode: Cellular-alloc
  Radio Information:
    Technology Preference: TD-SCDMA only  //现场表示使用的移动4G拨号,但是这里却是3G网络。
    Technology Selected: No Service
    Configured LTE Band = 1,3,5,38,39,40,41
  Modem Security Information:
    PIN Verification: Disabled
    PIN Status: PIN Requirement Disabled
    Number of PIN Retries Remaining: 3
    Number of PUK Retries Remaining: 10
    SIM Status: OK
        ICCID: 898600
 GPS Information:
  GPS Info:
    GPS State: Enabled
    GPS Mode Configured: Standalone
    Latitude: 0 Deg 0 Min 0 Sec North
    Longitude: 0 Deg 0 Min 0 Sec East
    Timestamp (UTC): 00/00/0000  00:00:00
    Local time: 00/00/0000  00:00:00
    Heading: 0.00, Velocity Horiz: 0.00, Velocity Vert: 0.00
    Height (MSL): -18.00 m
  Satellite Info:
经过分析发现Technology Preference: TD-SCDMA only 显示的状态有问题。现场表示使用的移动4G拨号,但是这里却是3G网络。
解决方法
 解决办法就是在拨号cellular接口下面将网络选择为4G网络LTE模式解决:
[h3c] controller cellular 1/0
[h3c-Cellular1/0] mode lte
