两台S10508做IRF堆叠,slot 1均装了二代防火墙板卡。
S10508的vlan接口与防火墙板卡接口处于同一网段,在105的vlan接口加入VPN实例之前,两个接口互ping能通,但是加入VPN实例之后,两个接口互ping不通。
1、在两边设备debugging ip packet,发现在交换机侧只能发出icmp echo,无法收到防火墙板卡的发出的icmp echo和icmp echo-reply,而防火墙板卡能够收到交换机发出的icmp echo并且给响应的icmp echo-reply。
交换机debug
*Jun 13 09:08:29:610 2019 SW ADDR/7/debug_icmp: ICMP Send: echo(Type=8, Code=0), Dst = 10.0.0.61
*Jun 13 09:08:31:831 2019 SW ADDR/7/debug_icmp: ICMP Send: echo(Type=8, Code=0), Dst = 10.0.0.61
*Jun 13 09:08:34:058 2019 SW ADDR/7/debug_icmp: ICMP Send: echo(Type=8, Code=0), Dst = 10.0.0.61
防火墙板卡debug
*Jun 13 09:08:30:076 2019 FW ADDR/7/debug_icmp: ICMP Send: echo(Type=8, Code=0), Dst = 10.0.0.58
*Jun 13 09:08:31:737 2019 FW ADDR/7/debug_icmp: ICMP Receive: echo(Type=8, Code=0), Src = 10.0.0.58, Dst = 10.0.0.61
*Jun 13 09:08:31:737 2019 FW ADDR/7/debug_icmp: ICMP Send: echo-reply(Type=0, Code=0), Src = 10.0.0.61, Dst = 10.0.0.58
2、尝试在交换机侧做流统,发现交换机ping防火墙流统来回都是5,防火墙有回报文给交换机,但是防火墙ping交换机流统inbound方向为5,但是outbound方向为0,交换机没有回防火墙。结合上面的debug判断交换机的内联口能够收到防火墙的报文,但是没有上送CPU处理。
交换机ping防火墙流统结果
Interface: Ten-GigabitEthernet1/1/0/1
Direction: Inbound
Policy: at
Classifier: at
Operator: AND
Rule(s) : If-match acl 3333
Behavior: at
Accounting Enable:
5 (Packets)
Direction: Outbound
Policy: at
Classifier: at
Operator: AND
Behavior: at
Accounting Enable:
5 (Packets)
防火墙ping交换机流统结果
Direction: Inbound
Policy: at
Classifier: at
Operator: AND
Behavior: at
Accounting Enable:
5 (Packets)
Direction: Outbound
Policy: at
Classifier: at
Operator: AND
Behavior: at
Accounting Enable:
0 (Packets)
3、经确认,客户开启了路由优化功能l3unicast-optimization enable。开启这个功能时,主控板不在承担硬件转发功能,这样可以提升主控板的处理能力和设备防攻击能力,在业务板的类型全都一致的情况下,开启路由优化功能可以提高整机的路由收敛性能。但是绑定vpn实例后,主控板相当于做一个代理功能,需要硬件表项来进行转发,所以需要关闭路由优化配置,才能正常转发。
在开启路由优化功能的时候,查看看底层l3表项,加入vpn实例后主控没有对应表项生成:
[SW-diagnose]bcm 4 0 l3/defip/show
Unit 0, Total Number of DEFIP entries: 12289
# VRF Net addr Next Hop Mac INTF MODID PORT PRIO CLASS HIT VLAN
关闭路由优化功能并重启对应vlan虚接口后,主控板硬件学到了相关表项,问题解决。
[SW]undo l3unicast-optimization enable
l3uc optimization mode disabled!
0 8 10.0.0.58/32 00:00:00:00:00:00 100001 0 0 1 32 n
0 8 10.0.0.56/29 00:00:00:00:00:00 100001 0 0 1 32 n
绑定VPN实例后,主控板相当于做一个代理功能,需要硬件表项来进行转发,所以需要关闭路由优化配置,才能正常转发。
关闭路由优化功能
