有些局点部署ADCampus方案项目时,可能没有多余服务器用于部署逃生服务器,但是客户又有在EIA服务器故障,无法连接到EIA服务器时需要访问逃生安全组的需求。这种情况下该怎么部署呢?
我们可以在Leaf设备上手工部署逃生安全组来实现上述需求。配置方法如下:
(1)创建逃生安全组的VSI:
vsi vsi3603
gateway vsi-interface 3603
arp snooping enable
flooding disable all all-direction
vxlan 3603
evpn encapsulation vxlan
mac-advertising disable
arp mac-learning disable
route-distinguisher auto
vpn-target auto export-extcommunity
vpn-target auto import-extcommunity
dhcp snooping binding record
(2)配置逃生安全组的DHCP地址池:
dhcp server ip-pool critical
vpn-instance vpn-default
gateway-list 201.0.0.1
network 201.0.0.0 mask 255.255.0.0
forbidden-ip 201.0.0.1
(3)配置逃生安全组的VSI接口:
interface Vsi-interface3603
ip binding vpn-instance vpn-default
ip address 201.0.0.1 255.255.0.0
mac-address 0066-0000-0001
local-proxy-arp enable
dhcp server apply ip-pool critical
distributed-gateway local
(4)配置Leaf下行口:
interface Bridge-Aggregation1024
port link-type trunk
port trunk permit vlan all
link-aggregation mode dynamic
stp tc-restriction
mac-based ac
dot1x
undo dot1x handshake
undo dot1x multicast-trigger
dot1x critical vsi vsi3603
dot1x critical eapol
mac-authentication
mac-authentication domain h3c
mac-authentication critical vsi vsi3603 url-user-logoff
port-security free-vlan 1 4094
至此,在Leaf设备上手工配置逃生安全组完成。
