Print
WA4320H-SI 刷胖版本的典型配置
2019-08-23发表
组网及说明
不涉及
配置步骤
1、首先升级扩展boot版本,要求扩展boot必须为7.13。
Enter your choice(0-9): ystem is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare....
The Extend BootWare is self-decompressing.........................Done!
*                 H3C WA4320H-SI BootWare, Version 1.07                    *
Copyright (c) 2004-2017 New H3C Technologies Co., Ltd.
Compiled Date       : Jun 19 2017
CPU Type            : ATHEROS AR9531
CPU L1 Cache        : 32KB
CPU Clock Speed     : 650MHz
Memory Type         : SDRAM
Memory Size         : 128MB
Memory Speed        : 450MHz
BootWare Size       : 512KB
Flash Size          : 16MB
PCB Version         : Ver.A
BootWare Validating...
Press Ctrl+B to enter extended boot menu...
BootWare password: Not required. Please press Enter to continue.
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Clear Super Password                                                  |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+C: Display Copyright
Ctrl+F: Format File System
Enter your choice(0-9): 7
|Note:the operating device is flash                                        |
|<1> Update BootWare By Serial                                             |
|<2> Update BootWare By Ethernet                                           |
|<0> Exit To Main Menu                                                     |
Enter your choice(0-2): 2
|<1> Update Full BootWare                                                  |
|<2> Update Extend BootWare                                                |
|<3> Update Basic BootWare                                                 |
|<4> Modify Ethernet Parameter                                             |
Enter your choice(0-4): 4
|Note:       "." = Clear field.                                            |
|            "-" = Go to previous field.                                   |
|          Ctrl+D = Quit.                                                  |
Protocol (FTP or TFTP) :tftp
Load File Name         :wap712h_art_v5.bin
                       :apwtu41039757_v7.13.btw
Target File Name       :wap712h_art_v5.bin
Server IP Address      :192.168.1.251 192.168.0.79
Local IP Address       :192.168.1.2 192.168.0.19
Gateway IP Address     :0.0.0.0
Enter your choice(0-4): 1
Loading..........Done!
381952 bytes downloaded!
Updating Basic BootWare? [Y/N]Y
Updating Basic BootWare..........Done!
Updating Extend BootWare? [Y/N]Y
Updating Extend BootWare...........Done!
2、升级完扩展boot之后重启设备(可以看到此时扩展boot已经是7.13版本),进扩展boot升级设备版本。
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU...
Booting Normal Extended BootWare
The Extended BootWare is self-decompressing..........................Done.
*                 H3C WA4320H-SI BootWare, Version 7.13                    *
Copyright (c) 2004-2019 New H3C Technologies Co., Ltd.
Compiled Date       : Jul 31 2019
CPU L1 Cache        : 32KB
Memory Type         : SDRAM
Memory Size         : 128MB
Flash Size          : 16MB
PCB Version         : Ver.A
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
 3、上传版本文件
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<8> Skip Authentication for Console Login                                 |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+Y: Change AP Mode
Enter your choice(0-9): 3
|<1> Download Image Program To SDRAM And Run                               |
|<2> Update Main Image File                                                |
|<3> Download Files(*.*)                                                   |
|         Ctrl+D = Quit.                                                   |
Load File Name         :apwtu41039757_v7.13.btw
                       :wa4300s-oasis.bin
Target File Name       :apwtu41039757_v7.13.btw
                       :wa4300s-oasis.bin//此处注意修改版本文件名称
Server IP Address      :192.168.0.79
Local IP Address       :192.168.0.46
Subnet Mask            :0.0.0.0
Enter your choice(0-4): 3
Loading.....................................................................
.................................................Done.
13698048 bytes downloaded!
Saving file flash:/wa4300s-oasis.bin .......................................
...........................................................Done.
 4、切换ap模式
Enter your choice(0-4): 0
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Please select the new mode
Current mode is Fit
|NO.  Mode        |
|1    Oasis Mode                                                           |//切换为云模式
|2    Fit   Mode                                                           |
|0    Exit        |
Enter your choice(0-2):1
This operation takes several minutes.Please wait...
Changed to Oasis mode successfully! Please reboot the system now!
5、切换完成后重启设备
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 0
CPU L1 Cache        : 32KB
Memory Type         : SDRAM
Memory Size         : 128MB
Flash Size          : 16MB
PCB Version         : Ver.A
starting...
配置关键点
1、第三步选择Download Files,否则会出现报错。
2、需要上传版本文件之后再切换ap模式。
3、刷完版本之后只能通过web管理。
APFat AP。初次使用云AP,给云AP上电后,云AP会默认开启4个无线服务:
l  其中一个称之为管理WIFI,也称内部WIFISSIDH3C_XXXXXXXXXXXX为设备mac地址后六位。管理WIFI供商铺内部员工管理使用,一般在2.4G频段工作,当设备未连接到绿洲时,通过连接管理WIFI在浏览器输入10.40.94.1myap.h3c.com访问本地web页面可进行本设备下的无线服务管理配置,一旦连接上绿洲,将只能通过绿洲平台进行统一的无线服务配置管理。
l  其余3个称为用户WIFI,也称商业WIFISSIDH3C_WiFi_1H3C_WiFi_2H3C_WiFi_3,不加密,不认证,不隐藏。当设备连接到外网,可为已经连接上用户WIFI的用户提供上网服务。
