Print
某局点S10510 PBR引流不生效问题处理经验案例
2019-08-29 发表
组网及说明
 不涉及
问题描述
现场两台105做了堆叠,slot3槽位有FW板卡,现在所有终端的网关在105上,需要使用PBR将流量引入到FW板卡上。
1、现场使用object-group匹配流量,发现pbr不生效,且有如下所示的提示
rule 0 permit ip source object-group 地市矿有线无线 destination object-group 集团公司有线无线
rule 5 permit ip source object-group 地市矿有线无线 destination object-group 服务器网段
[HeXin_S10510-Vlan-interface2]ip po
[HeXin_S10510-Vlan-interface2]ip policy-based-route 123
The operation is not supported in chassis 2 slot 1.
The operation is not supported in chassis 2 slot 0.
The operation is not supported in chassis 2 slot 2.
The operation is not supported in chassis 2 slot 4.
The operation is not supported in chassis 2 slot 3.
The operation is not supported in chassis 1 slot 1.
The operation is not supported in chassis 1 slot 0.
The operation is not supported in chassis 1 slot 2.
The operation is not supported in chassis 1 slot 4.
The operation is not supported in chassis 1 slot 3.
2、后续让现场不使用object-group,改用acl匹配,配置后发现设备提示资源不足,现场acl写了100条左右
通过查看display qos-acl resource信息,可以看到slot4IFP ACL只剩下310.
过程分析
1、本地测试object-group也是报错提示不支持
[10510]ip policy-based-route 123
[10510]dis device
Slot   Type                  State    Subslot  Soft Ver            Patch Ver
1/0    LSQM2MPUC0            Master   0        S7500E-7568P01      None
1/1    NONE                  Absent   0        NONE                None
1/2    LSQM1TGS48RSG0        Normal   0        S7500E-7568P01      None
1/3    NONE                  Absent   0        NONE                None
1/4    LSQM2GT24TSSC0        Normal   0        S7500E-7568P01      None
1/5    LSQM1TGS48RSG0        Normal   0        S7500E-7568P01      None
1/6    NONE                  Absent   0        NONE                None
1/7    NONE                  Absent   0        NONE                None
2、单板acl资源是固定的,从诊断可以看到,1框和2框slot 4的业务单板规格最小,inbound只有2K,而且还有768是保留的,其它单板规格都是8K或者4K,这块板卡成了瓶颈,其它单板都下发成功了,没有报错。
==== display qos-acl resource ====
Interfaces: XGE2/4/0/1 to XGE2/4/0/16 (chassis 2 slot 4)
Type             Total      Reserved   Configured Remaining  Usage
VFP ACL         1024       512        0          512        50%
IFP ACL          2048       768        560      720        64%
IFP Meter       1024       512        0          512        50%
IFP Counter    1024       384        0          640        37%
EFP ACL          1024       0          532        492        51%
EFP Meter        512        0          0            512        0%
EFP Counter      512        0          0          512        0%
解决方法
1、查阅相关资料发现,对于交换机来说,object-group只在mac portal认证支持微信认证的特性中支持,其他都是不支持的。所以后续建议配置具体
rule来匹配流量。
2、单板acl资源是固定的,因此应该根据现场业务量选择可以承载的单板。当设备提示资源不足时,一般解决办法是更换高规格的单板或者精简acl。
注意:如果对应单板没有放通相应的vlan,是不占用资源的。
