不涉及
1、首先升级扩展boot版本,要求boot版本必须为对应版本配套的7.18版本,版本文件中可获取
启动后Ctrl+B进入bootware,选择7进入bootware操作子菜单
* H3C WA5320 BootWare, Version 7.15 *
Copyright (c) 2004-2018 New H3C Technologies Co., Ltd.
Compiled Date : Aug 21 2018
CPU Type : ARM
CPU L1 Cache : 32KB
CPU L2 Cache : 256KB
CPU Clock Speed : 710MHz
Memory Type : DDR3 SDRAM
Memory Size : 256MB
Memory Speed : 533MHz
Flash Size : 32MB
PCB Version : Ver.B
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
|<1> Boot System |
|<2> Enter Serial SubMenu |
|<3> Enter Ethernet SubMenu |
|<4> File Control |
|<5> Restore to Factory Default Configuration |
|<6> Skip Current System Configuration |
|<7> BootWare Operation Menu |
|<8> Skip Authentication for Console Login |
|<9> Storage Device Operation |
|<0> Reboot |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Ctrl+Y: Change AP Mode
Enter your choice(0-9): 7
选择4设置更新bootware方式通过网线
|Note:the operating device is flash |
|<1> Backup Full BootWare |
|<2> Restore Full BootWare |
|<3> Update BootWare By Serial |
|<4> Update BootWare By Ethernet |
|<0> Exit To Main Menu |
Enter your choice(0-4): 4
选择4设置上传配置
|<1> Update Full BootWare |
|<2> Update Extended BootWare |
|<3> Update Basic BootWare |
|<4> Modify Ethernet Parameter |
设置上传文件名,此处是更新bootware,需上传boot文件;设置IP地址
|Note: "." = Clear field. |
| "-" = Go to previous field. |
| Ctrl+D = Quit. |
Protocol (FTP or TFTP) :tftp
Load File Name :wa5300.ipe
:apwa5300_v7.18.btw
Target File Name :wa5300.ipe
:apwa5300_v7.18.btw
Server IP Address :192.168.0.99 10.0.0.233
Local IP Address :192.168.0.98 10.0.0.2
Subnet Mask :255.255.255.0
Gateway IP Address :0.0.0.0
选择1更新bootware
Enter your choice(0-4): 1
Loading...........................Done.
1233920 bytes downloaded!
Updating Basic BootWare? [Y/N]Y
Updating Basic BootWare.....Done.
Updating Extended BootWare? [Y/N]Y
Updating Extended BootWare.........Done.
更新完成后选择0退回主界面并reboot
Enter your choice(0-4): 0
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Enter your choice(0-9): 0
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extended BootWare
The Extended BootWare is self-decompressing.................................
.Done.
重启完成后查看bootwre版本为7.18,再次Ctrl+B进入bootware,Ctrl+F格式化flash,此处注意需要格式化,避免空间不足导致版本解压失败
* H3C WA5320 BootWare, Version 7.18 *
Copyright (c) 2004-2019 New H3C Technologies Co., Ltd.
Compiled Date : Mar 8 2019
CPU Type : ARM
CPU L1 Cache : 32KB
Memory Size : 256MB
Flash Size : 32MB
PCB Version : Ver.B
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Warning:All files on flash will be lost! Are you sure to format? [Y/N]Y.....
Format success.
格式化完成后选择3进入ethernet子菜单
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Enter your choice(0-9): 3
选5设置有线网络配置,上传之前需要把胖AP版本文件名改成wa5300-oasis.ipe
|<1> Download Image Program To SDRAM And Run |
|<2> Update Main Image File |
|<3> Update Backup Image File |
|<4> Download Files(*.*) |
|<5> Modify Ethernet Parameter |
Enter your choice(0-5): 5
| Ctrl+D = Quit. |
Load File Name :apwa5300_v7.18.btw
:wa5300-oasis.ipe
Target File Name :apwa5300_v7.18.btw
:wa5300-oasis.ipe
Server IP Address :10.0.0.233
Local IP Address :10.0.0.2
配置完成后选择2,更新主版本文件
Enter your choice(0-5): 2
Loading.....................................................................
..............Done.
27445248 bytes downloaded!
Image file wa5300-oasis-boot.bin is self-decompressing...
Saving file flash:/wa5300-oasis-boot.bin ...................................
.............................Done.
Image file wa5300-oasis-system.bin is self-decompressing...
Saving file flash:/wa5300-oasis-system.bin .................................
升级完成后选择0退回主界面并且reboot
Enter your choice(0-5): 0
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
.Done.
CPU Type : ARM
CPU L1 Cache : 32KB
Memory Size : 256MB
Flash Size : 32MB
PCB Version : Ver.B
Loading the main image files...
Loading file flash:/wa5300-oasis-system.bin.................................
Done.
Loading file flash:/wa5300-oasis-boot.bin...................................
Done.
Image file flash:/wa5300-oasis-boot.bin is self-decompressing...............
...............................Done.
System image is starting...
Startup configuration file doesn"t exist or is invalid.
Line con0 is available.
Press ENTER to get started.
至此设备启动完成
1.需要升级设备bootware版本至7.18
2.升级完bootware后需要格式化Flash
3.对应版本文件需要修改成wa5300-oasis.ipe
云AP是Fat AP。初次使用云AP,给云AP上电后,云AP会默认开启4个无线服务:
l 其中一个称之为管理WIFI,也称内部WIFI,SSID为H3C_XXXXXX,XXXXXX为设备mac地址后六位。管理WIFI供商铺内部员工管理使用,一般在2.4G频段工作,当设备未连接到绿洲时,通过连接管理WIFI在浏览器输入10.40.94.1或myap.h3c.com访问本地web页面可进行本设备下的无线服务管理配置,一旦连接上绿洲,将只能通过绿洲平台进行统一的无线服务配置管理。
l 其余3个称为用户WIFI,也称商业WIFI,SSID为H3C_WiFi_1、H3C_WiFi_2、H3C_WiFi_3,不加密,不认证,不隐藏。当设备连接到外网,可为已经连接上用户WIFI的用户提供上网服务。
