Print
V7平台OSPF状态的OID返回值含义
2019-09-10 发表
问题描述
通过oid读取ospf邻居状态
解决方法
Type:                                      OBJECT-TYPE
OID:                                         1.3.6.1.2.1.14.10.1.6
Full path:                                        iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).ospf(14).ospfNbrTable(10).ospfNbrEntry(1).ospfNbrState(6)
Module:                                  OSPF-MIB
Parent:                                    ospfNbrEntry
Prev sibling:                          ospfNbrPriority
Next sibling:                          ospfNbrEvents
Numerical syntax:               Integer (32 bit)
Base syntax:                         INTEGER
Composed syntax:             INTEGER
Status:                                     current
Max access:                         read-only
Value list:                               1: down(1)
                                                  2: attempt(2)
                                                  3: init(3)
                                                  4: twoWay(4)
                                                  5: exchangeStart(5)
                                                  6: exchange(6)
                                                  7: loading(7)
                                                  8: full(8)
Default values:                     1: down (name)
Reference:                            OSPF Version 2, Section 10.1 Neighbor States
Description:    The state of the relationship with this neighbor.
