不涉及
现有环境中我方H3C交换机5130S-28P-EI与第三方认证平台进行认证对接,在对接后发现客户端总是认证失败,客户端使用的是该第三方认证平台的客户端。
客户端有一瞬间显示认证成功,但是立马就显示为认证失败,进入了guest vlan,guest vlan功能成功。在交换机上显示有上线成功而后认证失败的报文提示,如下:
%Jan 25 19:43:27:672 2013 H3C DOT1X/6/DOT1X_LOGOFF: -IfName=GigabitEthernet1/0/1-MACAddr=4439-c433-b3e8-VLANID=107-Username=20186087-ErrCode=0; 802.1X user was logged off.
交换机开debug,抓取认证时的认证报文,发现在认证过程中有如下一个报文:
*Jan 25 20:46:27:507 2013 H3C DOT1X/7/EVENT: PAE is in Authenticated state: UserMAC=4439-c433-b3e8, VLANID=107, Interface=GigabitEthernet1/0/1.
*Jan 25 20:46:27:507 2013 H3C DOT1X/7/EVENT: Sent authorization request: UserMAC=4439-c433-b3e8, VLANID=107, Interface=GigabitEthernet1/0/1.
*Jan 25 20:46:27:507 2013 H3C RADIUS/7/EVENT:
PAM_RADIUS: Processing RADIUS authorization.
*Jan 25 20:46:27:507 2013 H3C RADIUS/7/ERROR:
PAM_RADIUS: Authorization scheme is different from authentication scheme.
*Jan 25 20:46:27:511 2013 H3C DOT1X/7/EVENT: AAA processed authorization request: Result= Failure, UserMAC=4439-c433-b3e8, VLANID=107, Interface=GigabitEthernet1/0/1.
*Jan 25 20:46:27:512 2013 H3C DOT1X/7/PACKET:
Transmitted a packet on interface GigabitEthernet1/0/1.
报文提示AAA授权失败
后面将domain中的授权和计费这个两个参数改为none进行测试,
domain leagsoft
authentication lan-access radius-scheme uniaccess
authorization lan-access none
accounting lan-access none
发现客户端能认证成功,但是所在端口没有获取导下发的vlan号,从而进入了vlan 1 默认vlan号。
抓包发现,授权下发字段为“.”:
第三方认证平台更改了认证平台后台的字符串格式vlan格式,然后重启了认证模块后,授权vlan号成功下发。
