Print
E1接口模块故障打环方法
2019-10-30 发表
问题描述
E1接口模块故障打环方法
解决方法
1. 常用的打环点
图3-9 常用的打环点(反之亦然)
l 1打环点:
打环方法:在路由器上E1接口上配置loopbace local,在FE1接口下配置FE1 loopbace local
测试目的:排查路由器接口本身收发是否正常。
l 23打环点:
打环方法:将Router1与传输1之间的E1收发线缆短接或在传输上向左侧打环。
测试目的:排查Router1和传输1之间线路是否正常。
l 4打环点:
打环方法:在传输2上向左侧打环。
测试目的:排查传输网络是否正常。
l 5打环点:
打环方法:将Router1与传输1之间的E1收发线缆短接。
测试目的:排查Router1Router2直接整个物理链接是否正常。
l 6打环点:
打环方法:在Router2E1接口上配置loopbace remote/payload,在FE1接口下配置FE1 loopbace remote/payload
测试目的:排查整个链路,包括Router2是否正常。
2. 打环后如何进行线路排查:
l 通过路由器自环检测功能进行排查
将接口配置为主时钟,链路层协议配置为PPP,查看接口收发以22个包的步长匀速增长,在接口信息中显示loopback is detected,而且接口上没有错包增加,则表明链路正常,否则为异常。
<H3C>reset count interface
<H3C>dis int ser6/0:0
Serial6/0:0 current state: UP
Line protocol current state: DOWN
Description: Serial6/0:0 Interface
The Maximum Transmit Unit is 1500, Hold timer is 10(sec)
Derived from E1 6/0, Unframed mode, Baudrate is 2048000 bps
Internet protocol processing : disabled
Link layer protocol is PPP, loopback is detected
LCP closed
Input: 22 packets, 336 bytes
0 broadcasts, 0 multicasts
0 errors, 0 runts, 0 giants
0 CRC, 0 align errors, 0 overruns
0 dribbles, 0 aborts, 0 no buffers
0 frame errors
Output:22 packets, 336 bytes
0 errors, 0 underruns, 0 collisions
0 deferred
l 通过ping包进行排查
将接口配置为主时钟,链路层协议配置为HDLC(因该协议默认UP),并将接口统计清空,然后向对端ping一定数量的包,查看接口收发是否与ping包相等,如相等,而且接口上没有错包增加,则表明链路正常,否则为异常。
[H3C]dis int ser2/0
Serial2/0 current state: UP
Description: Serial2/0 Interface
Physical layer is E1-F, baudrate is 1984000 bps
fe1 timeslot-list 1-31
Internet Address is 2.2.2.2/24 Primary
Link layer protocol is HDLC
Output queue : (Urgent queuing : Size/Length/Discards) 0/100/0
Output queue : (Protocol queuing : Size/Length/Discards) 0/500/0
Output queue : (FIFO queuing : Size/Length/Discards) 0/75/0
Last clearing of counters: 14:04:14 Thu 02/12/2009
Last 300 seconds input rate 0.14 bytes/sec, 1 bits/sec, 0.00 packets/sec
Last 300 seconds output rate 0.14 bytes/sec, 1 bits/sec, 0.00 packets/sec
Input: 16 packets, 352 bytes
0 frame errors
Output:16 packets, 352 bytes
0 deferred
 附:2种经典打环测试方法              (作者:黄伟龙)
一.问题描述:
经常遇到用户说路由器接好线缆后,两边不能通信;或者通信正常过一段时间,现在突然不能用了;另外就是网络时断时通。在遇到这种情况时,我们一般会先让用户看一下两端的2层封装协议是否相同(如:PPP HDLC)IP是否在同一网段,电信打环是否证明两端线路良好。这些做完后,如果没有问题,哪么我们接下来要做的就是打环来测试。也就是我们接下来要介绍的方法。这里介绍的是用PPP协议。
二.网络拓朴:
三.网络说明:
1XY都是路由器。
2AB是一般的协议转换器。在上面有一些打环的按钮。
3XA一般通过是V24V35线缆,
4AB一般是光纤,租用电信的,这一部分就是电信打环时能确认电信哪端线路是否是好用的。   注意:电信只会给你确认A—B段线路是否好的。
四.第一种方法(通过看InputOutput报文数量是否相等)
打环测试
第一步
1.在X端口上打环。
       [X-Serial2/1] fe1 loopback local
2 <X>reset count interface
  [X]reset count interface
   过几十秒后
       <X>dis int s 2/1
Serial2/1 current state :UP
Line protocol current state :DOWN
Description :  Serial2/1 Interface
Internet Address is 192.168.2.2/24
LCP closed
Output queue : (Urgent queue : Size/Length/Discards)  0/50/0
Output queue : (Protocol queue : Size/Length/Discards) 0/500/0
Physical layer is synchronous, Loopback,Baudrate is 64000 bps
Interface is DCE, Cable type is V35
    Last 300 seconds input rate 0.00 bytes/sec, 0.00 packets/sec
    Last 300 seconds output rate 0.00 bytes/sec, 0.00 packets/sec
    Input: 22 packets, 336 bytes   Input Output 的都相等。
           0 frame errors
           0 deferred
DCD=UP  DTR=UP  DSR=UP  RTS=UP  CTS=UP
结论:端口是好的。模块没有问题。
第二步
1.在A光电转换器上打本地环。
   过几十秒后
2.在端口上去掉打环。
       [X-Serial2/1]undo fe1 loopback
<X>dis int s 2/1
LCP closed
    Input: 55 packets, 840 bytes   Input Output 的都相等。
           0 frame errors
    Output:55 packets, 840 bytes
           0 deferred
结论:从端口到A的本地线缆是好的。
第三步
1.在B光电转换器上打远程环。
   过几十秒后
2.在A光电转换器去掉打环。
<X>dis int s 2/1
LCP closed
    Input: 77 packets, 1176 bytes   Input Output 的都相等。
           0 frame errors
    Output:77 packets, 1176 bytes
           0 deferred
结论:从端口到B的线缆是好的。
第四步
1.在B光电转换器去掉打环。
2Y上的。
[Y-Sierial2] fe1 loopback local
   过几十秒后看X路由器
<X>dis int s 2/1
LCP closed
    Input: 99 packets, 1512 bytes   Input Output 的不相等。
           0 frame errors
    Output:87 packets, 1480 bytes
           10 errors, 0 underruns, 0 collisions
           0 deferred
结论:说明路由器YB的线路有问题。
五.第二种方法(通过Debug PPP的报文来看接口输出的报文是否给接口的输入报文相同。)
<X>
<X>
<X>t m
% Current terminal monitor is on
<X>t d
% Current terminal debugging is on
<X>debu ppp lcp pack int  s 2/0
<X>
*0.1110711 X PPP/8/debug2:
  PPP Packet:
      Serial2/0 Output LCP(c021) Pkt, Len 18  ---à这是报文发出的方向
      State reqsent, code ConfReq(01), id 7c, len 14
      MRU(1), len 4, val 05dc
      MagicNumber(5), len 6, val 001156e1
*0.1110990 X PPP/8/debug2:
  PPP Packet:
      Serial2/0 Input  LCP(c021) Pkt, Len 18
      State reqsent, code ConfReq(01), id 7c, len 14  <---这是报文接收的方向
      MagicNumber(5), len 6, val 001156e1   可以看出红色部分的和绿色部分的完全相同,
*0.1111271 X PPP/8/debug2:            说明从接口发出的报文,完全给接口接收到了。证
  PPP Packet:                                   明没有丢包,这段打环是没有问题的。
      Serial2/0 Output LCP(c021) Pkt, Len 14
      State reqsent, code ConfNak(03), id 7c, len 10
      MagicNumber(5), len 6, val 0010f802
*0.1111510 X PPP/8/debug2:
  PPP Packet:
      Serial2/0 Input  LCP(c021) Pkt, Len 14
*0.1111750 X PPP/8/debug2:
  PPP Packet:
      State reqsent, code ConfReq(01), id 7d, len 14
      MagicNumber(5), len 6, val 00111233
*0.1112030 X PPP/8/debug2:
  PPP Packet:
接下来和上面的步骤一样,通过分段排除法,一步一步打环测过去,看哪一步有问题。这样就可以找出问题来。
后记:
1.  以上作的测试是以路由器版本为VRP3.30VRP3.40为基础的。
2.  对于模块为E1/CE1封装成PPP协议的同样适用。
3.  两种方法中,第一种简单易用,但第二种可以分析报文(只是复杂一些)
4.  对于版本为VRP1.74基本差不多。以下是VRP1.74的情况:
[RTD]
[RTD]int s 0
[RTD-Serial0]loop
[RTD-Serial0]
[RTD-Serial0]qui
[RTD]info enable
[RTD]info con deb
[RTD]
[RTD]debu ppp packet int s 0
[RTD]
[RTD]
Serial0
  PPP O LCP(c021) Pkt, Len 18           ---à这是报文发出的方向
  State starting, code ConfReq(01), id 1, len 14
  MagicNumber(5), len 6, val 081b09b2
Serial0
  PPP I LCP(c021) Pkt, Len 18             <---这是报文接收的方向
  State reqsent, code ConfReq(01), id 1, len 14
Serial0                                 可以看出红色部分的和绿色部分的完全相同,
  PPP O LCP(c021) Pkt, Len 14           说明从接口发出的报文,完全给接口接收到了。
  State reqsent, code ConfNak(03), id 1, len 10      证明没有丢包,这段打环是没有问题的。
  MagicNumber(5), len 6, val 6e925916
Serial0
  PPP I LCP(c021) Pkt, Len 14
