Print
E1和E1-F基础知识
2019-10-30 发表
问题描述
E1和E1-F基础知识
解决方法
1、 接口的工作方式
2、接口基础知识
配置前E1-F和E1口
controller E1 2/0/0   //E1口
 using e1
controller E1 2/0/1   //E1口
 using e1
interface Serial1/0/0  //E1-F口
 link-protocol ppp
 fe1 unframed
interface Serial2/0/0:0
 link-protocol ppp
 ip address dhcp-alloc
interface Serial2/0/1:0
 link-protocol ppp
①E1-F接口
//配置E1-F接口工作在E1(非成帧)
[Quidway]int s1/0/0
[Quidway-Serial1/0/0]fe1 unframed
[Quidway-Serial1/0/0]ip address 1.1.1.1 24
//配置E1-F接口工作在成帧(缺省)
[Quidway]int s1/0/0
[Quidway-Serial1/0/0]undo fe1 unframed
[Quidway-Serial1/0/0]fe1 timeslot-list ?
  INTEGER<1-31>  Timeslots in range, separated by ',' or '-'
[Quidway-Serial1/0/0]fe1 timeslot-list 1-10
[Quidway-Serial1/0/0]ip add 1.1.1.1 24
②E1接口
//配置E1接口工作在非通道化
[Quidway]controller E1  2/0/0
[Quidway-E1 2/0/0]using e1
生成一个接口:interface Serial2/0/0:0
//配置E1接口工作在CE1通道化(缺省)
[Quidway-E1 2/0/0]using ce1
[Quidway-E1 2/0/0]channel-set 20 timeslot-list ?
[Quidway-E1 2/0/0]channel-set 20 timeslot-list 1,2
[Quidway-E1 2/0/0]
%Jun  4 06:45:52:085 2004 Quidway PHY/2/PHY:    Serial2/0/0:20: change status to up
[Quidway-E1 2/0/0]channel-set 10 timeslot-list 3-7
[Quidway-E1 2/0/0]
%Jun  4 06:48:55:928 2004 Quidway PHY/2/PHY:    Serial2/0/0:10: change status to up
[Quidway]int Serial2/0/0:20
[Quidway-Serial2/0/0:20]ip address 1.1.1.2 24
//配置E1接口工作在PRI通道化
[Quidway]controller E1  2/0/1
[Quidway-E1 2/0/1]using ce1
[Quidway-E1 2/0/1]pri-set ?
  timeslot-list  Lists of the timeslots of the PRI set
  <cr>
[Quidway-E1 2/0/1]pri-set timeslot-list ?
[Quidway-E1 2/0/1]pri-set timeslot-list 1-15 ?
  <cr>
[Quidway-E1 2/0/1]
[Quidway-E1 2/0/1]pri-set timeslot-list 17,18
 Another pri-set exists.//在一个CE1/PRI接口上同时只能捆绑出一个pri set。
[Quidway-E1 2/0/1]dis cur
controller E1 2/0/0
 channel-set 20 timeslot-list 1-2
controller E1 2/0/1
 pri-set timeslot-list 1-16
interface Aux0
 async mode flow
interface Ethernet0/0/0
interface Ethernet0/0/1
 link-protocol ppp
 ip address 1.1.1.1 255.255.255.0
interface Serial2/0/0:10
 link-protocol ppp
interface Serial2/0/0:20
 link-protocol ppp
interface Serial2/0/1:15
 link-protocol ppp
return
   通信两端配置要保持一致(display  fe1 serial x/x 或display controller e1 x/x查看)工作模式(成帧或非成帧)、帧格式、CRC校验方式、编码格式、线路空闲码、帧间填充符。
   CISCO E1接口默认帧格式为CRC4,我司E1接口默认帧格式为NO-CRC4,两者互联时请使之保持一致。
案例解析:AIS告警误检问题
   如果线路上正常传输的数据为全1码流,这种情况通常出现在E1工作在非通道化模式下,而且空闲码为FF,这时当没有业务数据传输时,则线路上传输的是全1的空闲码,表现为AIS告警。
   解决该问题的办法是:在路由器上配置undo detect-ais 命令,即不检测AIS命令,或把帧间填充改为7E。
[Quidway]dis fe1 s1/0/0
Serial1/0/0
Basic Configuration:
  Work mode is E1 framed, Cable type is 75 Ohm unbalanced.
  Frame-format is no-crc4.
  Line code is hdb3, Source clock is slave.
  Idle code is 7e, Itf type is 7e, Itf number is 4.
  Loopback is not set.
Alarm State:
  Receiver alarm state is Loss-of-Signal.
  Transmitter is sending remote alarm.
Historical Statistics:
  Data in current interval (94 seconds elapsed):
    94 Loss Frame Alignment Secs, 0 Framing Error Secs,
    0 CRC Error Secs, 0 Alarm Indication Secs, 94 Loss-of-signals Secs,
    0 Code Violations Secs, 14 Slip Secs, 0 E-Bit error Secs.
[Quidway]dis controller e1 2/0/0
E1 2/0/0 current state :DOWN
Description : E1 2/0/0 Interface
  Work mode is E1 unframed, Cable type is 75 Ohm unbalanced.
  Loop back is not set.
Alarm State:
  Data in current interval (158 seconds elapsed):
    12 Loss Frame Alignment Secs, 0 Framing Error Secs,
    0 CRC Error Secs, 0 Alarm Indication Secs, 158 Loss-of-signals Secs,
    0 Code Violations Secs, 1 Slip Secs, 0 E-Bit error Secs.
3、指示灯解释
指示灯 含义
LINK (Green) 灯亮表示收到载波信号,并且没有告警,灯灭表示没有收到载波信号或有以下五种告警之一:AIS、LFA、LMFA、RAI
ACT (Yellow) 灯灭表示没有数据收发,灯闪烁表示数据收发
指示灯 含义
LINK/ACT (Green) 灯亮表示收到载波信号,灯灭没有收到载波信号。灯闪烁表示有数据收发。
LP/AL  (Yellow) 灯亮表示接口处于环回状态(loopback),灯闪烁表示有以下四种告警之一:AIS、LFA、LMFA、RAI,灯灭表示既无环回又无告警。
如果LP/AL指示灯闪烁:表示四种告警之一:AIS,LFA,LMFA,RAI
其含义如下:
      Loss-of-Signal:载波丢失;
      Alarm Indication Signal:告警指示
      Loss of Frame Alignment:帧同步丢失
      Remote Alarm:远端告警
      Loss of Multiframe Alignment:复帧同步丢失
如果E1-F接口没有插线缆,LP/AL 灯闪烁则代表载波丢失是正常情况。
BNC头是75欧的,RJ45的是120欧的,两者可以通过转换盒转换
